Analysis Plus Clear Oval speaker cables, 8ft, NIB, and video cables
0 Members and 1 Guest are viewing this topic. Read 780 times.
mikeg1
Clear Oval speaker cables, 8ft pair with spades, new in box, original owner, $85($125). Decided not to set-up a second system.
The name says it all. Clear Oval is such a transparent cable, we've even made the outer jacket of clear PVC. Designed just like our highly-acclaimed Oval 12, but using 14 awg wire instead of 12 awg, Clear Oval offers much of the same performance but at a much lower price. It makes beautiful use of our patent-pending hollow oval woven design in which every conductor wire is statistically as close to the return current as every other wire. The result is evenly distributed current density that adds up to better signal transfer than conventional solid-conductor cable designs. Clear Oval is handcrafted with special high-purity oxygen free copper combined with a computer-matched dielectric to give the best possible response. It is factory terminated with crimped-on 1/4"-5/16" gold-plated spade lug connectors, gold plated BFA style bananas or gold plated pin connectors. The difference between Clear Oval and other cables is clear. And so is the performance. Outer Dimensions - 11mm x 8mm
_______________________________________ ____________________________
Better Cables 1M HDMI to DVI in excellent condition, original owner, 2006 Better Vision Editor's Choice, $50($109)
Crystal clear digital connection for your HDMI to DVI-D connections
- Supports all HDTV formats and PC resolutions up to 1920X1200
- EXCLUSIVELY BUILT by BetterCables, $50($109)
see bettercables website for more details.
Audioquest HDMI-in to DVI-out converter, new with box, bought one extra, $18($30)
