Need assistance on DIY supply in San Diego, CA region
0 Members and 1 Guest are viewing this topic. Read 2435 times.
2gumby2
I am stationed at a U.S. military base in Japan and will be coming to San Diego (North Island) during the first week of March for some Temporary Duty. I am planning to build a phono preamp from Colin Electronics (www.colinelectronics.com) and I need to purchase some parts for the project. I need to find a source for some 6-32 threaded metal standoff spacers to mount the PCB in the chassis along with the screws and washers to go along with them. I also need to buy some 22 gauge hook-up wire. Any good electronic parts stores in the area?
art
    • Analog Research-Technology
Re: Need assistance on DIY supply in San Diego, CA region
« Reply #1 on: 20 Feb 2008, 05:39 pm »
One suggestion..............order them on-line from Mouser or Digi-key. Ok, you would have to buy a bag of 100, and pay shipping. But on the plus side, you could have them waiting there for you.
Expect to pay a quarter apiece for stand-offs.
An alternative......although somewhat hit-or-miss........hardwares stores sometimes have stand-offs in those plastic pull-out trays in the hardware section. At least here they do. The trick is to find a hardware store these days.
Good luck.
Pat
2gumby2
« Reply #2 on: 21 Feb 2008, 03:40 am »
Pat, thank you for the generous offer. I only need 4. PM sent.    Best regards, Mark
tanchiro58
« Reply #3 on: 21 Feb 2008, 04:32 am »
Hi Mark,
When doing my DIY stuffs I do not need any standoff spacers. I just go to Home Depot or OSH and buy a bag of 6-32 shorter or longer than 1" brass screws, washes and nuts to use for holding tight the pcb to the enclosure box.
BRN
« Reply #4 on: 21 Feb 2008, 06:48 am »
If you only need 4 get them at RatShack.
skchow
« Reply #5 on: 21 Feb 2008, 07:19 am »
When I used to live in San Diego, this is the place I would go to when I needed electronic parts...
Gateway Electronics
222 Chesapeake Dr. San Diego, CA 92123 858-279-6802
http://www.gatewayelex.com/
2gumby2
« Reply #6 on: 22 Feb 2008, 03:39 am »
Thanks! I'll stop by Gateway and take a look around.
art
« Reply #7 on: 26 Feb 2008, 08:00 pm »
Care package on the way.
Pat
