0 Members and 1 Guest are viewing this topic. Read 16067 times.
Sign me up. It seems like a cheap enough tweak to add and see how it sounds. I assume I just connect it to the ribbon binding posts?
It's 12dB/oct with a 2.5uF cap.B
Definitely a thought and definitely at a good price.
A 0.2mH coil will work fine for experimenting.I should mention the add-on tweeter has a 20 Ohm impedance so as not to load down your amplifier at high frequencies.
Quote from: Brian Cheney on 19 Feb 2008, 04:25 amA 0.2mH coil will work fine for experimenting.I should mention the add-on tweeter has a 20 Ohm impedance so as not to load down your amplifier at high frequencies. Thanks Brian, I can already see John posting about reversing polarity....
Sensitivity of the tweeter is 88dB/1W/1m. Fortunately it does not have to be very loud, thus the adjustable damper.
