0 Members and 1 Guest are viewing this topic. Read 11217 times.
Yes Mike, go ahead and see if it works. I think I would be interested if it doesn't need immediate overhaul and if the price is reasonable.If the pinch rollers are just dry, I can probably salvage them with this "rubber renue" stuff that I have (MG chemicals). It really revitalizes dry rubber.Sounds like you may have the original box and packing (styrofoam). Are you in Colorado?thanks, Russell
From time to time I am asked to transfer old RTR tapes, typically musicians' recital tapes recorded at 3.75 or 7.5 ips, to CDR for continued safekeeping. I know CDR is not forever, but I do use archival quality discs.I have an old Revox A77, but the play heads are seriously worn and it's a half track anyway with speeds of 7.5 and 15 ips, so of very limited utility as many of the tapes presented to me are 3.75 ips.My trusty old Sony TC-366 seems to have settled into permanent senile dementia, so I have decided to look for something appropriate on the used market. I don't have much familiarity with RTRs, but from what I have gleaned over the last few weeks, these are machines I might be looking at, the first Sony mentioned only because I can get one locally for $125 - I understand there is some contention about the worth of this machine:Sony TC-580, TC-765Pioneer 707Technics 1520Teac A-7300Revox A-77It is not appropriate to spend a lot on this, as I don't do much of this type of transfer and, moreover, the recording characteristics don't count for anything - just the playback - so flexible EQ is a bonus.Keep in mind I need 3.75 and 7.5 ips, can do without 1 7/8 and 15 ips, and I live in Victoria, BC.Can anyone make any recommendations for a reasonably priced (say $200 - 400) good sounding machine?Thanks.
Thanks Gary but, as I say, I bought a Pioneer RT 707 and am very happy with it.It sounds good, appears to be in good shape and as a bonus it is standard rack width which means it doesn't steal a lot of rack space because it is deep and wide rather than high. It even has rack "ears".Russell
