Got new AT440MLa this weekend *problems*
0 Members and 1 Guest are viewing this topic. Read 1872 times.
gus6464
« on: 18 Feb 2008, 07:42 am »
This was my first attempt ever at installing a cartridge and I must say it went very well. I have a Rega Planar 2 and used the Stevenson ARC protractor from vinyl engine and the Shure SFG-2. I must say that the cart is a huge step up from the Shure V-series cart that the TT came with in terms of tracking. On some LPs like ABBA the sound is a bit thin when compared to the Shure but I am guessing it's because cart has yet to break-in. On other LPs the highs are a lot more detailed and I have been hearing new things on most songs. I was also worried about the hum that some people were reporting but I have to say mine is completely hum free. Next upgrade will be Michell Technoweight but it will be a bit since I have major upgrade coming in on Tuesday and Wednesday in the form of an Arcam A80 integrated and Dali Ikon 2 speakers. I got an awesome deal on both at audiogon that was just too hard to pass up.
« Last Edit: 18 Feb 2008, 09:17 am by gus6464 »
gus6464
Re: Got new AT440MLa this weekend
« Reply #1 on: 18 Feb 2008, 08:44 am »
All of a sudden now I get no sound from the left speaker. I checked to see if the cartridge wire was loose but it's in place. What could be causing this?
JimJ
  • Ut Prosim
Re: Got new AT440MLa this weekend *problems*
« Reply #2 on: 18 Feb 2008, 10:06 am »
Re-check everything...the connections at the cart, the plugs going into the phono input, the speaker wires just to be sure :)
Wayner
« Reply #3 on: 18 Feb 2008, 12:36 pm »
Flip the left and right cables around at the preamp and see if the problem switches to the right channel. If it didn't the probllem is with the pre-amp or something else down stream. Make sure the shield part of the RCA jacks are making contact.
Wayner
gus6464
« Reply #4 on: 18 Feb 2008, 10:31 pm »
Wayner
Ok I will try that when I get home. So what if when I switch the cables the sound switches to left speaker? I just don't understand how it was working perfectly fine one second and the next one channel goes out.
gus6464
« Reply #5 on: 19 Feb 2008, 01:19 am »
Ok so I just got home and reversed the RCAs from the TT to the phono preamp and now I get sound from the left instead of the right. So it's definitely something wrong in the tonearm or the cartridge. What can I do?
Edit: I think I figured out what's wrong. I checked the cartridge connectors and the solder has come off the white and green connectors. The little slider bracket now hangs on the cable without making contact. Is there anything I can do besides needing an entirely new rewire? I tried to tape the solder and connector together with electrical tape but it didn't work.
« Last Edit: 19 Feb 2008, 01:46 am by gus6464 »
twitch54
« Reply #6 on: 19 Feb 2008, 02:19 am »
electrical tape !!!  even uncle 'Rube' wouldn't try that one, LOL ! get out your soldering gun kiddo ! if your lucky you can just "re-sweat" it back together.
gus6464
« Reply #7 on: 19 Feb 2008, 03:31 am »
Haha I went out to Lowe's real quick and got a soldering gun with some solder. Was lucky enough that I just needed a tiny bit of solder and presto! It works perfectly now although this experience now makes me want to rewire my RB250 myself. It never ends!!!  :green:
Wayner
« Reply #8 on: 19 Feb 2008, 01:38 pm »
A soldering iron is good to own when you have a table. Cartridge wires are a very small gauge and prone to breakage.
Now get listening!
Wayner  :D
