My Shigaraki - Ack - MHDT Paradisea Comparison
0 Members and 1 Guest are viewing this topic. Read 1026 times.
greg7
« on: 16 Feb 2008, 06:59 pm »
I recently bought a 47 Labs Shigaraki DAC and transport. The MHDT Paradisea+ and Ack Dack 2.0 were two other DACs I seriously considered.
A friend sent his MHDT Paradisea+ and Ack Dac 2.0 (with the optional upgrade teflon output caps) for comparison with the offer that I could buy either if I preferred it to the Shigaraki DAC. While his Ack Dac came with the Ack silver digital cable and I also own an 47 Labs OTA digital cable, I chose to use only my Cablepro Vista digital cable with all three (I originally found little difference between the OTA and Vista with the Shigaraki combination). I also used only stock power cables. My system is listed at the end of the review for reference. The Shigaraki transport was used with each DAC.
MHDT Paradisea+
This unit came with the Western Electric 396A tube installed. My friend also sent a couple of other NOS tubes. Sonically it archetypically tube: smooth, soft, colorful, slow and bassy. All of this may have simply been a function of the WE 396A. However, for all of its pleasantness it had two major flaws. First, it also got easily confused by complex music (something the Shigaraki has never exhibited). Second, it had a glare in the upper midrange that was immediately noticeable and caused nervous tension. In retrospect this could have been tube glare. My initial suspicion was that it was digital related, though, so I never felt inclined to try other tubes. Because of these issues, it annoyingly drew too much attention to itself.
Ack Dac 2.0
The Ack had slightly better resolution than the Shigaraki and a similarly neutral, pure demeanor. It didn't have the glare the MHDT exhibited. It subjectively wasn't as pure or "fresh" as the Shigaraki, however. More troubling still, it completely lacked involvement. It seemed to place a barrier between me and the presentation -- the natural flow and ease I was accustomed to with the Shigaraki was distinctly lacking with the Ack. It was completely and obviously cerebral, whereas the Shigaraki seems to completely remove itself from the chain.
I was fully prepared, even hoping to replace the Shigaraki with either the MHDT or the Ack. Certainly I prefer the aethetics of either to the Shigaraki by a large margin. Being my first non-oversampling DAC, I wasn't certain where the Shigaraki stood in relation to any of its non-oversampling competition. However, I judge the MHDT or Ack sonically inferior by my preferences.
System:
Leben CS-600 with NOS tubes
Vandersteen 1C Loudspeakers
Acoustically treated room with dedicated AC line
Yamamoto equipment rack
Cablepro Revelation power strip (purist, no AC filtration)
Miscellaneous cables (Zu, Cardas, Cablepro and stock AC cords)
« Last Edit: 17 Feb 2008, 03:48 am by greg7 »
IronLion
Re: My Shigaraki - Ack - MHDT Paradisea Comparison
« Reply #1 on: 16 Feb 2008, 07:10 pm »
Thanks for the comparison.  I'd be interested to know what digital cable you used on these DACs, and if you ever tried different ones on the DACs to see if and how they affected the resulting music?
-EDIT:  Whoops, I just realized you addressed this in the first paragraph...
denjo
« Reply #2 on: 18 Feb 2008, 04:42 am »
Greg7
Just realised you have a fantastic integrated amplifier in the Leben 600!  :drool: Was wondering what your views of the Leben are. Read some very good things about it but was concerned that volume had to be "pedal down to the floor" with some tracks. And, I heard it gets quite hot to the touch.
Best Regards
Dennis
« Last Edit: 18 Feb 2008, 12:23 pm by denjo »
greg7
« Reply #3 on: 18 Feb 2008, 06:09 pm »
Greg7
Best Regards
Dennis
It's a keeper, although I'm still tempted to explore chip amps. With stock tubes it was only "OK" as to be expected. With NOS tubes it's quite good -- musical, not hi fi sounding. It's my first tube amp so I can't provide any comparisons. It certainly sounds a lot better than the stack o' Naim it replaced (200-202-HC2-Napsc2). I'm in a smaller room and I never get the volume up past 10:00. It mainly depends on the sensitivity of the speakers, of course, with only 30 watts. But it actually runs pretty cool to be honest. The chassis never gets beyond "warm".
