specific preamp
0 Members and 1 Guest are viewing this topic. Read 5812 times.
guest1632
  • Guest
specific preamp
« on: 16 Feb 2008, 06:33 pm »
Hi all,
Just was wondering if anyone has tried either the Ys-Audio Symphony Plus or the DIYhifisupply Basie Preamp?  Still on my search for the Preamp that I'll be keeping for a long time. Unfortunately, don't have a lot of mula to spend.
Ray
Brad
Re: specific preamp
« Reply #1 on: 16 Feb 2008, 07:04 pm »
Are you looking for just tube preamps?
In that price range, I'd consider a Grounded Grid.
I know DougS is a big Melos fan:
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1208310788
The Eastern Electric Minimax is supposed to be quite good, but I haven't heard one.
Non-tube, I would definitely try out one of the Prometheus TVC preamps
Hope this helps
guest1632
  • Guest
Re: specific preamp
« Reply #2 on: 16 Feb 2008, 07:26 pm »
Hope this helps
Hi Brad,
At present, I do have a TVC. Yes, considering the GGP. Just was looking for input from others who might have the Symphony Plus or the Basie preamp.
Ray
ajzepp
Re: specific preamp
« Reply #3 on: 16 Feb 2008, 08:40 pm »
I'm starting to think that Ray needs his own damn circle  :duh:
guest1632
  • Guest
Re: specific preamp
« Reply #4 on: 16 Feb 2008, 09:29 pm »
Hey that's what happens when you are researching this stuff. LOL.
I figured if I got a GGP, would probably upgrade the pot, the output caps, the Selector switch, and maybe some parts in the power supply.
Ray
ajzepp
Re: specific preamp
« Reply #5 on: 16 Feb 2008, 09:53 pm »
I'm all about research too, but I think you've covered just about every preamp in existence...sooner or later ya just gotta PICK one, bro  :thumb:
guest1632
  • Guest
Re: specific preamp
« Reply #6 on: 16 Feb 2008, 10:10 pm »
Actually, not true. I've narrowed it down to just a few half dozen heheh. Besides the GGP, the Ys-audio, DIYhifisupply basie, the foreplay extended III an an AE3. That's it. The output impedance is important. That's why I chose those preamps.
Ray
Brad
Re: specific preamp
« Reply #7 on: 16 Feb 2008, 10:34 pm »
Would you buy or build the GGP?
I heard the Foreplay with Paramours in my system last weekend.
VERY impressive on jazz/vocals. :thumb:
I've also heard the GGP before, but my system and room were drastically different then.
It was very neutral.
I think we've all needed our own circle during major system change times  :wink:
guest1632
  • Guest
Re: specific preamp
« Reply #8 on: 16 Feb 2008, 10:53 pm »
Well, I have a line on two of them. One is already built with some mods. The oother one is still a kit.
Ray
ajzepp
Re: specific preamp
« Reply #9 on: 16 Feb 2008, 11:11 pm »
Well dang, man, I hope the one you end up with kicks some major ass for ya!
Re: specific preamp
« Reply #10 on: 16 Feb 2008, 11:27 pm »
Hi Ray,
     I was wondering why the output Z is important? Are you running long interconnects? Just wondering.
Cheers.
guest1632
  • Guest
Re: specific preamp
« Reply #11 on: 16 Feb 2008, 11:54 pm »
Hi Ray,
Cheers.
Hi Steve,
Well the reason is this: My SKA amp has a feedback circuit at the input which when matched with the correct impedance below 800 ohms will produce the best PSRR, and theoretically should sound its best. Greg unfortunately is banned from this board, so he can't explain this. That's how I understand it anyhow.
my observations so far are the 12a*7 family in general is just this side of neutral on the slight warm side. The 6SN7 family seems to be a more robust sound. The 6922 family seems to be somewhere in the middle. Now I'm not knocking any particular sound at all. I would preferr to not have any sound at all. Hence your 11A Steve.
I'm coming from a solid state side. So that's all I have for now.
Now, if anyone has any comments on those preamps, I'm interested. The one thing I've heard consistent is the 6922 tubes get noisy fairly fast. I'd be looking at the 6H30's Steve hence the Juicy Music Peach. Mark does make a good point. The more tubes in a system, the more smear is the sound.
Ray
Rocket
Re: specific preamp
« Reply #12 on: 17 Feb 2008, 12:17 am »
Hi Ray,
I was just about to recommend the juicy music and sas labs preamps:
http://www.enjoythemusic.com/magazine/equipment/1206/juicymusic_merlin.htm
Why buy from China when you can purchase a local product.
Regards
Rod
ajzepp
Re: specific preamp
« Reply #13 on: 17 Feb 2008, 12:27 am »
Right on, Rod...that is a huge factor in the gear I buy, too.  :thumb:
Brad
Re: specific preamp
« Reply #14 on: 17 Feb 2008, 12:30 am »
I've heard nothing but very positive comments on the SAS preamps.
I did think they were above the price range Ray is looking in.
They don't come up often used, so that might be a hint...
Wasn't there a newer model below $1k?
Ray - do you have any way to try some of these in your system?
pbrstreetgang
Re: specific preamp
« Reply #15 on: 17 Feb 2008, 12:47 am »
You all are saying that you prefer the supertube to the 6922? I use 6922 stuff but havent messed too much with the mig tube but the ARC and BAT crowd has some minor grumblings for the 6922 if I am interpreting it right
opnly bafld
Re: specific preamp
« Reply #16 on: 17 Feb 2008, 12:47 am »
Yes, the 7A at $989 and it is very good.
http://www.sasaudiolabs.com/price1.htm
Lin
doug s.
  • makin' music
Re: specific preamp
« Reply #17 on: 17 Feb 2008, 04:53 am »
yup, melos is killer.  you will be hard-pressed to beat the sonics of an sha-1 for $500, even if you quadruple your budget...
a bud of mine finally broke down & got one; he's kicking himself that he dint buy a sha-gold-r several years ago, instead of the rogue magnum 99 he bought...
there's a maestro on agon presently, for $600 asking price.  it has more reliable alps pots instead of the sha-gold-r's better sounding but problematic photentiometer pots - like the sha-1, but more inputs/features.  it should have remote wolume control, as well.  it will sound as good as an sha-1:
http://cls.audiogon.com/cgi-bin/cls.pl?preatube&1208267683
doug s.
guest1632
  • Guest
Re: specific preamp
« Reply #18 on: 17 Feb 2008, 05:15 am »
Ok, guys, let me answer you this way. first, this impedance issue. Both of the SAS Labs preamps, the impedance is higher than what is needed. Secondly, the price. The JM prees, like the Peach are great, but also sell for the 1500 price tag. Now when I get some money, I'll just have to buy all of these and listen for myself. heheh.
The Symphony Plus is making claims that this model rivals $4,000 preamps. The JM will rival preamps 3 times its pricetag. So that's where I am guys.
if pricetag were no object, would probably get this Audio Horizons or an 11A, and get a different power amp.
Now, since I'm leaning towards the GGP, the Ys-audio is also in the same ballpark price and impedance. Wouldn't have to get it built. Just don't know how it sounds. Yeah, the GGP is made here in America. You make a good point. So is the AE3 from AES, the Cary people. It uses 6SN7 tubes.
Ray
Rocket
Re: specific preamp
« Reply #19 on: 17 Feb 2008, 09:40 am »
Hi Ray,
The Juicy Music 'Merlin' sells for $795us and the DIY HiFi Supply 'Bassie' is $600us as a kit.  Factor in shipping costs and the cost of building the 'Bassie' and its about the same price as the JJ.
I've been guilty of purchasing a cheaper product in the past and almost everytime I have regretted it.
Good luck with your decision.
Rocket
