RCA or XLR outputs on Modwright Transporter
0 Members and 1 Guest are viewing this topic. Read 1997 times.
Frank S.
« on: 15 Feb 2008, 11:47 pm »
Hi all,
Right now I'm running my Modwright Transporter via balanced outputs to my BAT VK-52SE preamp.  I'm replacing my BAT with an Audio Research Ref 3 preamp which has single ended and balanced inputs and I'm thinking I may switch over to the single ended outputs on the Transporter.  What do you think?  Are Dan's single ended outputs the best way to run the Transporter?  Thanks
Frank
pearsall001
  • AAD 2001 monitor
Re: RCA or XLR outputs on Modwright Transporter
« Reply #1 on: 16 Feb 2008, 12:33 am »
Try them both & see which one you like the best. All things being equal, the XLR will trump single ended overall.
Frank S.
« Reply #2 on: 16 Feb 2008, 01:13 am »
I'd love to do that, but I don't have a spare set of RCA Stealth Metacarbon interconnects laying around..............
ted_b
« Reply #3 on: 16 Feb 2008, 01:35 am »
No freaking brainer.  Use your Metacarbon XLR beauties and don't look back.  I use Nanofiber RCA's on my Modwright TP, only because they are the best cable, not necessarily because RCA outs are the best.  I've a/b'd some very high $$ XLR's on it and no contest, the Stealth Nanofibers are the best in my system by a long shot.  But yes, if I had Nanofiber XLR's I'd choose them.   The TP is fully balanced, and the ARC Ref 3 will like the marriage I would guess.  :thumb:
Frank S.
« Reply #4 on: 16 Feb 2008, 01:37 am »
Thanks Ted  :thumb:
