Wireworld Silver Starlight 52 (5 squared) HDMI, Analysis Plus Clear Oval spk
0 Members and 1 Guest are viewing this topic. Read 2201 times.
mikeg1
Wireworld Silver Starlight 52 (5 squared), HDMI to HDMI, 1M, latest model, original owner, includes box, used in a second system that is no longer needed. $150($300) each. Two cables for sale. Add 3% for paypal please.
From the website: Wireworld Series 52 HDMI cables are the first flat digital video cables in the world. Their revolutionary design* is only .15" (4mm) thin and .7" (18mm) wide. In addition to the obvious advantages of greater flexibility and easier concealment, this design provides dramatically improved performance, including the ability to deliver 1080p video signals over 50 feet (15 meters) without using an amplifier or repeater.. Series 52 HDMI/DVI cables are also rated UL-CL3/FT4 for in-wall installations.
Wireworld's proprietary flat cable design has significantly lower loss and higher precision than the conventional round HDMI cable design, which has been used in computer cables for decades. The Series 52 cables feature die-cast metal connectors for superior durability and shielding of the proprietary cable terminations, which maintain the cable's precise 100-ohm impedance all the way to the plug contacts. Rather than the standard nickel, these contacts have a thick layer of silver under their gold plating, reducing contact losses by more than half.
The top-of-the-line Silver Starlight includes signal conductors made of the finest material utilized in any digital video cable, OCC (Ohno Continuous Cast) silver-clad copper of 6N (>99.99997%) purity. Starlight and Ultraviolet have silver-clad OFC conductors, but Starlight's conductors contain much more silver for increased efficiency. Chroma has OFC conductors and molded connectors, while Island brings the superior performance of Wireworld's flat cable design into the entry-level price range. At every price level, Series 52 HDMI and DVI cables provide amazing improvements in the definition, depth and contrast of digital video images.
_______________________________________ ____________________________
Clear Oval speaker cables, 8ft pair with spades, new in box, original owner, $85($125). Decided not to set-up a second system.
The name says it all. Clear Oval is such a transparent cable, we've even made the outer jacket of clear PVC. Designed just like our highly-acclaimed Oval 12, but using 14 awg wire instead of 12 awg, Clear Oval offers much of the same performance but at a much lower price. It makes beautiful use of our patent-pending hollow oval woven design in which every conductor wire is statistically as close to the return current as every other wire. The result is evenly distributed current density that adds up to better signal transfer than conventional solid-conductor cable designs. Clear Oval is handcrafted with special high-purity oxygen free copper combined with a computer-matched dielectric to give the best possible response. It is factory terminated with crimped-on 1/4"-5/16" gold-plated spade lug connectors, gold plated BFA style bananas or gold plated pin connectors. The difference between Clear Oval and other cables is clear. And so is the performance. Outer Dimensions - 11mm x 8mm
Better Cables 1M HDMI to DVI in excellent condition, original owner, 2006 Better Vision Editor's Choice, $50($109)
Crystal clear digital connection for your HDMI to DVI-D connections
- Supports all HDTV formats and PC resolutions up to 1920X1200
- EXCLUSIVELY BUILT by BetterCables, $50($109)
see bettercables website for more details.
Audioquest HDMI-in to DVI-out converter, new with box, bought one extra, $18($30)
