**SOLD FS: Stello (April Music) DA220 MKII DAC SOLD**
0 Members and 1 Guest are viewing this topic. Read 3648 times.
jman66
** 2/14/2008 - The DAC has been sold **
For Sale, the Stello DA220 MKII DAC.
I am the 2nd owner of this wonderful DAC, functionally sound and used in a smoke, pet and child free listening area. This is the MK II model that has a USB input for computer playback. The prior owner exclusively used the DAC via USB from a MAC Mini. I used the digital out from a Squeezebox3 to the DAC with great success.
The DAC uses the AKM4395 chip and is feature rich for the $$$. Several digital input/output connection options as well as Class A single-ended and true balanced outputs. The only thing lacking is a BNC connection but a handy diy'er could easily swap one in.
This is the best sounding DAC I've had in my system so far. Downsizing/restructuring has taken me in a different system direction and has now displaced the DA200, thus the reason for sale.
Original box, owners manual and power cord are included.
Cosmetically, the DAC is fine except for a single tiny blemish I found on the right side of the case which is about 1/10th of a mm in length.
Original Price: $1650
Selling Price: $800, plus shipping - local pick is also an option - Northern New Jersey.
Payment options are Paypal (plus 3%), check or money order. Check must clear before item gets shipped.
Thanks for looking!
-jim
FEATURES:
- Supports upto 24Bit/192kHz upsampling
- Sampling Rate Selectable: Bypass, 48kHz, 96kHz, 192kHz
- True 24Bit Delta-Sigma DAC
- Digital De-emphasis
- Phase Selection: 0, 180 Degree
- On-chip PLL eliminates jitter
- Custom designed 6th order digital filtering circuitry
- Special buffer stage between digital filter and analog out
- Separate transformers for analog and digital circuits
- High quality electronic components and gold plated RCA connectors
- 4 Digital Inputs (1 AES/EBU, 1 Coaxial, 1 Coaxial or USB selectable, 1 Toslink)
- 3 Digital Outputs (1 AES/EBU, 1 Coaxial, 1 Toslink)
- 2 Analog Outputs: 1 Balanced Output (XLR) & 1 Unbalanced Output (RCA)
- Full Balanced Class A Operation Analog Stage
- Supports 44.1kHz/16Bit (Bypass), 48kHz, 96kHz and up to 24bit / 192kHz Upsampling (Sampling Rate Selectable)
- True 24 Bit Delta-Sigma DAC
- Sixth Order Digital Filter
- Digital Outputs for Recording
- Phase Selection : 0, 180 Degree
- On-chip PLL eliminates Jitter
- Full Balanced, Full Class A operation Analog Output Modules
SPECS:
DIGITAL INPUT
AES/EBU (XLR) Balanced Input 110 Ohm
Coax1, 2 (2 RCA Unbalanced) Input 75 Ohm
USB 1.1 input
Toshiba Link Optical Input
DIGITAL OUTPUT
AES/EBU (XLR) Balanced Output
Coax (RCA Unbalanced) Output
Toshiba Link Optical Output
ANALOG OUTPUT
1 RCA Unbalanced Stereo
1 XLR Balanced Stereo
ANALOG OUTPUT VOLTAGE 1.3 Vrms
OUTPUT WORD LENGTH 16, 18, 20, 24 Bits
DYNAMIC RANGE 110 dB Typ.
SIGNAL-TO-NOISE RATIO 120 dB Typ.
DISTORTION 0.003 %, 1 kHz
0.002 %, 10 kHz
0.002 %, 20 kHz
FREQUENCY RESPONSE 10 Hz - 55 kHz (+- 3dB)
SAMPLING FREQUENCY 44.1 kHz to 192 kHz, Selectable. 192 kHz Default
POWER REQUIREMENTS 100/117/220/230/240 VAC, 50 or 60 Hz
DIMENSIONS (WHD) & WEIGHT 435 x 85 x 350 mm, 7.5 Kg
My buying/selling references:
http://cgi.audiogon.com/cgi-bin/fb.pl?user=Jman66
Manufacturer link:
http://www.aprilmusic.com/products/products_da220mkii.htm
Review link:
http://www.soundstage.com/revequip/stello_da220mkii_followup.htm
Pictures:
« Last Edit: 14 Feb 2008, 05:29 pm by jman66 »
santacore
Re: FS: Stello (April Music) DA220 MKII DAC
« Reply #1 on: 13 Feb 2008, 04:41 pm »
PM sent
werner52
Re: **SOLD FS: Stello (April Music) DA220 MKII DAC SOLD**
« Reply #2 on: 21 Feb 2008, 12:58 am »
