HDMI splitter
0 Members and 1 Guest are viewing this topic. Read 3693 times.
Bill O'Connell
  • Retired . Music Lover
HDMI splitter
« on: 13 Feb 2008, 11:02 am »
Hi Guys,
  What is out there that will take my HDMI out from my comcast cable box so I can feed it into my Kuro 60 and also run into my Panny AV receiver. I guess I'm looking for something with one input that splits the HDMI into two outputs. Any suggestions.
 Bill
Parnelli777
Re: HDMI splitter
« Reply #1 on: 13 Feb 2008, 01:18 pm »
avahifi
    • http://www.avahifi.com
Re: HDMI splitter
« Reply #2 on: 13 Feb 2008, 01:45 pm »
I found a nice three input one at Radio Shack.  It even learns to switch inputs from signals sent by your various remote controls.
Frank Van Alstine
avahifi
Re: HDMI splitter
« Reply #3 on: 13 Feb 2008, 01:45 pm »
I found a nice three output one at Radio Shack.  It even learns to switch inputs from signals sent by your various remote controls.
Frank Van Alstine
John Casler
Re: HDMI splitter
« Reply #4 on: 13 Feb 2008, 03:18 pm »
Hi Bill,
I think the Oppo is also a good one.
http://www.oppodigital.com/hm31/
Bill@LakeGeorge
Re: HDMI splitter
« Reply #5 on: 13 Feb 2008, 07:55 pm »
I don't think that the oppo will work it is 3 in and one out he is looking for one in and 2 out.  I have a brand new one listed here http://www.avsforum.com/avs-vb/vbclassified.php?do=ad&id=2557 that works, I bought 2 and now only need one.
Bob in St. Louis
Re: HDMI splitter
« Reply #6 on: 13 Feb 2008, 08:38 pm »
One HDMI in, Three outputs.
1080p HD ready.
With remote control ('cause you need another one on sitting on your coffee table).
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=3029&seq=1&format=2
Bill@LakeGeorge
Re: HDMI splitter
« Reply #7 on: 14 Feb 2008, 03:30 pm »
1080p HD ready.
Again this is a 3 in and 1 out.  3 X 1 not 1 X 3
low.pfile
Re: HDMI splitter
« Reply #8 on: 14 Feb 2008, 04:14 pm »
splitter = multiplier
so this is what the OP needs:
http://store.cwc-group.com/hdmi.html
The HDMI Splitter allows a single HDMI device, such as a DVD player and a Satellite set-top box to display on up to 4 HDMI displays (HDTVs or Projectors).
no experience with it though
good luck
tvyankee
Re: HDMI splitter
« Reply #9 on: 14 Feb 2008, 04:21 pm »
This is what you want, at least if you want to put something else there like a dvd player at the same time you can.  All for $100.00
I have 2 of them and they work fine.
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=3728&seq=1&format=2
Good luck.
John Casler
Re: HDMI splitter
« Reply #10 on: 14 Feb 2008, 05:03 pm »
My BAD :duh:
