Help with technical question
0 Members and 1 Guest are viewing this topic. Read 1765 times.
raztec
« on: 12 Feb 2008, 10:43 am »
I've got a pre-amp + amp (coming) with which I want to run my front R&L speakers.
And I've got a receiver (without pre-outs) to run the remaining 5.1 speakers.
How can I set up my system to do that?
Can I have the analog signal from the CDP/DVD to be going to both the receiver and the pre-amp using a y-cable?  Or should I run the digital out of the CDP/DVD to the receiver (which has a built in DAC) and the analog out of the CDP/DVD to the pre-amp?
Thanks for your help,
Raz
Ichinichi
Re: Help with technical question
« Reply #1 on: 12 Feb 2008, 03:58 pm »
I'm a newb too, but I'll take a stab at it.
Optical out to receiver, analog to pre-amp assuming that optical out does not preempt the analog out since you're technically pulling the signal before the DAC in the CDP.
JimJ
  • Ut Prosim
« Reply #2 on: 13 Feb 2008, 10:05 pm »
So you don't have a 5.1 processor?
I'd go with a real 5.1 proc + multichannel amp or seperate amps...
Jampot
« Reply #3 on: 13 Feb 2008, 10:35 pm »
Raz,
At the moment you presumably run the digital out to your receiver - have you tried the analogue out to the receiver and if so which sounds better?
If you are happy using the analogue out just reroute the front channels via the new pre-amp. You may have to tinker with volume settings but it is workable, particularly if your player has the facility to adjust the balance using a test tone. Your proposal to use a combination of analogue and digital may work in a similar fashion - providing the signals are available concurrently (like Inchinichi says) and they don't get out of sync.
Providing you don't try to connect both 'new amp' and receiver to the front speakers at the same time (:o) I think you can try experimenting without risk of damage.
The other possibility which occurs to me is that if the Receiver has a tape connection you could connect from the tape out to the new pre. Volume control may still be hit and miss.
Jim
