0 Members and 1 Guest are viewing this topic. Read 4069 times.
Ray I would stick with the 50k pot value as supplied with the kit. If I was building it myself I would use a 50k DACT pot. It avoids the lead inductanceof the resistors used in the kit and my time is worth the 60 dollar difference in price. A lot of tube preamps have a 100k pot in them and are designedto work this value pot. Also a 100k input value does not load down other tube gear like a tube DAC used with the preamp and maintains a good ratio of output source impedance to input impedance for good RF rejection. You might ask the kits' designer if there is any advantage to using a 100k potover a 50k pot in the kit or if there any incompatibility that would prevent using a 100k pot in the kit. As always it is probably advisable to seek specific technical information about a product directly from the manufacturer rather than relying on second hand information or conjecture.Scotty
The circuit board traces on the Goldpoint pot are considerably longer from the surface mount resistors to the switch contacts than the DACT pot which means more lead inductance. This may or may not be a problem sonically, cautious soul that I am I would stick with DACT pot because it is the evil I know.Scotty
I've listened to DACT, Gold points and TVC's. They are all great. However, how each one behaves in an individual circuit is difficult to predict. Before splurging on the above, I would first try a PEC carbon pot from either DIYhifisupply or from Digikey. Its really the only pot I would use. If cost is no object then try the DACT, Gold Points or TVC's. But...you may be happy with just the PEC. The PEC is about $23 from Digikey and a little more expensive from DIYHifiSupply since he hand picks them for lowest noise, etc...Best,Anand.
Interesting I was looking at this Audio Mangus selection and wondering how it would be in the TGG but dismissed it, is this the same one you are suggesting? http://www.audio-magus.com/product_p/peckka.htm
Quote from: poseidonsvoice on 10 Feb 2008, 04:55 pmI've listened to DACT, Gold points and TVC's. They are all great. However, how each one behaves in an individual circuit is difficult to predict. Before splurging on the above, I would first try a PEC carbon pot from either DIYhifisupply or from Digikey. Its really the only pot I would use. If cost is no object then try the DACT, Gold Points or TVC's. But...you may be happy with just the PEC. The PEC is about $23 from Digikey and a little more expensive from DIYHifiSupply since he hand picks them for lowest noise, etc...Best,Anand.Hi Anand,So how does the Peck sound? Does it track ok on lower levels? That's the main reason for replacing the pot that's in there.I don't know how the Transcendentsound atenuator is. I heard somewhere that his atenuator somehow restricts dynamics. Don't know if that's true or not. Ray
