0 Members and 1 Guest are viewing this topic. Read 9158 times.
I have an Ack!dac 2.0 w/ the Auricap upgrade on both the output and bypass caps. What do you guys feel are the best caps in this application for best transparency and solid bass. My friend has the DynamiCaps in his Ack! and it's a step up in the transparency dept. Any other suggestions? Thanks, Mark
The high load impedance in line level systems swamps any contribution that a capacitor might have so long as you use a sufficiently large value to keep the capacitors reactance insignifigant compared to the load impedance.Film capacitors by nature have extremely smooth impedance transfer functions which make any tonal or transient contributions impossible.Film capacitors (especially poly and teflon) also have extremely low non linearity which precludes intermodulation and distortion.Then when you use the capacitor as a coupler/blocker the load impedance takes control of the circuit and the contribution of the capacitor is divided by the ratio of load impedance and the impedance of the capacitor (and the capacitor is damn impressive to start with).If you set the corner frequency of the coupling capacitor at 1hz (8uf@20kohm) then it's contribution is swamped 1000 to 1 by 1000hz if you set the corner frequency at 0.1hz (80uf@20kohm) then the capacitors contribution is swamped 10,000 to 1 by 1000hz. Use something affordable and decent size and don't allow yourself to be misled.
The job of power supply and local supply rail bypass capacitors is simply to short out any signal which might be present.The supply rails ideally would be the equivilant of ground with a DC offset.The only 'special' quality a bypass capacitor can have is low impedance over as wide a band as possible (microdynamics and inner-detail are pure foolishness).The impedance transfer function of capacitors is shaped like the letter 'V' (for Vanquishing snake oil salesmen and idoliters).Capacitance causes the impedance to have a downward slope at the low end of the spectrum and inductance causes the impedance to have an upward slope at the high end of the spectrum.Inductance is mostly due to the lead length so 'special' capacitors aren't likely to be much improved in terms of inductance unless they feature a low inductance lead design (Litz, ribbon, tubular) which you rarely see though countless manufacterers claim to have gone to the ends of the earth to make every possible improvement to their product.The bottom of the 'V' is the self resonant frequency of the capacitor where it achieves it's lowest impdance.Film/Foil type capacitors which have lower ESR have a higher 'Q' at their self resonant frequency and consequently a lower impedance in the vicinity of the self resonance frequency but at lower and higher frequencies their impedance is dictated by their capacitance and inductance so they aren't necessarily going to net you much improvement over deposited metal types.The physical size and price of film and foil types might in the end limit the level of performance you can achieve in your design.The best way to counter lead inductance is to use multiple smaller capacitors which divides lead inductance by the number of units employed, raises the self resonant frequency by the square root of the number of units employed and results in lower ESR for a given capacitor type.Lower impedance at the lower end of the spectrum is a simple function of the total amount of capacitance.Capacitors with more capacitance in a smaller space will allow you to achieve a lower impedance path to ground and locate it closer to where it needs to be which means you would likely use electrolytics bypassed by say ceramics to extend the bandwidth into the RF spectrum.When combining different capacitors you must consider their impedance functions, design the circuit so there is no possible parallel resonance between the capacitors employed.Again don't allow yourself to be misled.
Last time I checked, we enjoy musical reproduction via listening, not by connecting the amps electrical output directly to various bodily orifices.
Any DIYers out there hear a difference between a Solen Polyprop. and a Sonicap or Auricap? I'm willing to bet that I know the answer.
Quote from: markC on 7 Feb 2008, 02:11 amAny DIYers out there hear a difference between a Solen Polyprop. and a Sonicap or Auricap? I'm willing to bet that I know the answer.Markc,That would be nice of you if you tell me (or us) the differences between these caps. Thanks.Tan
Quoting a bunch of technical terms has done nothing to answer the o/p's question.Terms such as ESR, ESL, lead length and inductance are not points of concern when choosing an output coupling cap. Which is the title of the thread.Those items would be of interest in a bypass cap, which he has also expressed interest in.While low ESR should be preferential in that case, in some applications it can cause problems. (Some 3-terminal regs will oscillate at worst, and at best cause noise peaking in the output.)If you guys insist on spouting techno-babble, you should also be prepared to be ready to give more insight.But as for coupling caps, in specific:A lot will depend on personal tastes. Even different types from any manufacturer will sound different from ones using the same basic construction. Oval vs round axial caps is one case that comes to mind. Stacked foil films that are square vs ones that are rectangular is another.On paper, none of that should matter. If you feel that it doesn't, then you can chose your coupling caps from a catalogue. (And don't try to start your own high-end audio company.) Otherwise, you are going to have to listen to them. And, yes, they will sound different.Pat
I clearly explained why any reasonably chosen coupling capacitor cannot contribute to the sound of an componet.I also gave a perspective (or insight) which others don't give which makes it clearer.If you don't understand why not just ask and learn rather than posture?......
Coupling caps meeting certain minimal characteristics all sound the same. Have you empirically verified this? No, I don't need too, because they can't....
Quote from: Daryl on 8 Feb 2008, 01:37 amI clearly explained why any reasonably chosen coupling capacitor cannot contribute to the sound of an componet.I also gave a perspective (or insight) which others don't give which makes it clearer.If you don't understand why not just ask and learn rather than posture?......Circular arguments allways work best when they're not clouded by actual empirical verification. Quote from: imaginary conversationCoupling caps meeting certain minimal characteristics all sound the same. Have you empirically verified this? No, I don't need too, because they can't....
