Audiomagus SubLine to drive DeepHemp?
0 Members and 1 Guest are viewing this topic. Read 3987 times.
dudesinmexico
« on: 5 Feb 2008, 08:13 am »
I purchased from Louis a pair of Compact Hemps about one year ago and now I am considering to add a Deep Hemp
to my system. My source Slimdevices Squeezebox 3 and amplification is provided by a Tripath based Charlize amp,
so I was wondering if anyone with a similar setup has tried this device to drive the Deep Hemp:
http://www.audio-magus.com/SubLine_Subwoofer_Connector_p/slv2.htm
Any other ideas that will not hurt the wallet?
-dudesinmexico
Jampot
Re: Audiomagus SubLine to drive DeepHemp?
« Reply #1 on: 5 Feb 2008, 10:18 am »
If you read here -
http://www.audiocircle.com/index.php?topic=49300.msg444259#msg444259
Vinnie Rossie explains that you shouldn't need the gadget with the Deep Hemp.
If you have any reservations or choose another makers sub, check out the Hornshoppe Circle for Ed's Magic Cable.
Lovely set up :green:
Jim
Vinnie R.
    • http://www.vinnierossi.com
« Reply #2 on: 5 Feb 2008, 01:23 pm »
If you read here -
Jim
Jim is correct!  You can connect the speaker outputs of any tripath-based amp directly to to the speaker-level inputs of the Omega DeepHemp or DeepHemp Cube.
Best regards,
Vinnie
dudesinmexico
« Reply #3 on: 7 Feb 2008, 05:01 pm »
Vinnie,
thanks a lot for your explanation. One last question: does the Deep Hemp amplifier have inputs for both the the L and R channels?
If not, I guess I still need some kind of mixer. So, from what I understand, I can simply connect the Compact Hemp and the Deep Hemp in
parallel for each channel, right?
dudesinmexico
Vinnie R.
« Reply #4 on: 7 Feb 2008, 05:09 pm »
Vinnie,
dudesinmexico
dudesinmexico,
Yes, it has both Left and Right Speaker Level Inputs and RCA (line-level) inputs.
Yes, you can connect your Compact Hemps and Deep Hemp in Parallel.
Best regards,
Vinnie
JDK1
« Reply #5 on: 8 Feb 2008, 02:40 pm »
Hi all:
I have my primary speaker cables run from the RWA Sig30.2 to my Omega XLS, then speaker line jumpers down to the dual Deephemp Cubes (I have the XLS sitting atop the Cubes, with a cork barrier between them). Louis already had the plate amp jumpers in place, so I just had a couple of cable connections to make - very clean and easy.
- Jonathan
Louis O
« Reply #6 on: 13 Feb 2008, 10:21 pm »
Many thanks for the great posts and it's true that all the all the t amps can be connected via speaker level inputs on all the Deephemps.
Thanks again,
Louis
