Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
FryKleaner Questions.
0 Members and 1 Guest are viewing this topic. Read 1800 times.
syyma
5 Feb 2008, 12:19 am »
Is it possible to use Frykleaner to burn in electrolytics and film/foil
capacitor? Thanks in advance.
hagtech
Facilitator
Re: FryKleaner Questions.
5 Feb 2008, 05:27 am »
Yup. Just put it across the outputs.
jh
Finnski
Newbie
Reply #2 on:
29 Jun 2011, 02:05 pm »
Hi, syyma!
Did you do as jh advised you, and put it [the film/foil capacitor] across the outputs?
I am in the process of burning in some Mundorf capacitors for my loudspeaker crossovers. Being rather a rookie in electronics, I would highly appreciate accurate description of the procedure.
fandersen
Reply #3 on:
1 Jul 2011, 05:35 am »
If you don't have a FryKleaner, this thread over on DIY Audio describes a similar procedure.
http://www.diyaudio.com/forums/class-d/101344-tripath-input-coupling-caps-5.html
Finnski
Newbie
Reply #4 on:
1 Jul 2011, 09:44 am »
Ahh, thank you, fandersen!
I have searched here and there for such a circuit, but ended up buying a FryKleaner. It will arrive in Oslo, Norway in some days. Thanks for your tip all the same!
Kind regards,
Finnski
Other Stuff
Hagerman Technology
hagtech
