0 Members and 1 Guest are viewing this topic. Read 14070 times.
I'm a believer in balanced power. In my system, an equi=tech feeds the source component. This particular model was designed for sources, so it doesn't have enough juice for an amp. It isn't that I don't believe balanced power can help clean up an amp's sound too, just that I don't have a unit that can do so.I'm also using Alan Maher's PEs. These share duplex outlets with your components. It is strange that such a small device can have such a large effect, but that is what I hear. They are one tweak I can't see not trying.IMHO, it is best to start with dedicated circuits first. They make a substantial improvement. Circuits shared with lights, dimmers, fans, etc. inject grit into your system. Though I don't like to admit it, the outlet itself also makes a difference (in my system anyway). I recently replaced my old "audiophile" outlets with new ones and am surprised by the difference. Still checking these out so can't say I've heard all they can do. So, I'd suggest the dedicated circuits to begin. They can cost very little depending upon how long the run is, etc. Then I'd try the PEs. Give them 10 days to be most effective. Lots of info about these on an industry thread. I don't believe these two measure are very system dependent so should work for lots of folks. Phil
.... These chokes are a very affordable isolation technique, highly recommended by Alan Maher.
Please stop your tiff with BrianM (the misinformed vs. the uninformed), it makes those who find power conditioning beneficial (even Alan Maher's products) look ridiculous.
Hi Robin,No, I haven't tried that. Can you explain more about the setup? Is the BPT plugged into the top of the duplex and the PE in the bottom? Where does the choke go? I'm a little slow with this stuff.Phil
Robin,Occam is right,the Hammond Chokes do not give you any isolation. What you and Alan have re-discovered is the slave inductor. I have been using old transformers with the secondary taped up and plugged into the wall in parallel with my front end and my power amp for nearly 20 years. I have a 15lb. E core transformer on the front end and two 22lb. E core transformers in parallel with my power amp.When you have a large inductor in parallel with your load it stores electrical energy in the form of a magnetic field in the core of the inductor. When there is a demand for current from the wall to the component, a power amp for example, reproducing a large transient, the voltage sags just a little. As this happens the magnetic field in the inductor collapses and current is supplied to the line which helps reduce the voltage sag. This all happens at nearly the speed of light. In a nutshell the slave inductor acts like the coil in your car, when the magnetic field collapses in it out squirts electricity. This is similar to having a much larger transformer in the power supply of your equipment. A slave inductor may help to reduce the minute to minute voltage variations in your power under a no load condition but it will be useless in long term under or over-voltage conditions. These inductors are doing nothing to remove garbage from the electrical power supplied to you. Scotty
...These inductors are doing nothing to remove garbage from the electrical power supplied to you. Scotty
Quote from: Phil on 7 Feb 2008, 03:02 amHi Robin,No, I haven't tried that. Can you explain more about the setup? Is the BPT plugged into the top of the duplex and the PE in the bottom? Where does the choke go? I'm a little slow with this stuff.PhilNo slower than myself Phil,,, and that's a fact. OK, I have the BPT in the bottom outlet and the choke in the top outlet, this puts the choke in parallel with the BPT, and I will have a 20A IEC Liberator cord(it's in the mail) on the back of the BPT with a PE IV in series. These chokes come with an 8" set of lead wires, 1 wire being slightly longer than the other. It's just a matter of connecting an AC plug to the 2 wires, the longer being the hot (AC plug's wide pin) and NO ground connection. With my placement, 8" didn't cut it so I simply used an old lampshade cord which had a white line on the hot side of the cord so it was an easy install. The Hammond 193M is twice the size of the 193L which most folks are using to isolate each component. With a component hookup , it's preferable to have the choke as close to the component as possible so you would have your component plugged into the top outlet and a PE in the lower outlet. Ideally you'd use an IEC Liberator cord on the end of the component and the choke plugged into that. I hope I have this right but if I don't, you have a general idea and experiemnting with location is half the fun anyways.Hope this layman's explanation helps. Cheers,Robin
Quote from: satfrat on 7 Feb 2008, 03:37 amQuote from: Phil on 7 Feb 2008, 03:02 amHi Robin,No, I haven't tried that. Can you explain more about the setup? Is the BPT plugged into the top of the duplex and the PE in the bottom? Where does the choke go? I'm a little slow with this stuff.PhilNo slower than myself Phil,,, and that's a fact. OK, I have the BPT in the bottom outlet and the choke in the top outlet, this puts the choke in parallel with the BPT, and I will have a 20A IEC Liberator cord(it's in the mail) on the back of the BPT with a PE IV in series. These chokes come with an 8" set of lead wires, 1 wire being slightly longer than the other. It's just a matter of connecting an AC plug to the 2 wires, the longer being the hot (AC plug's wide pin) and NO ground connection. With my placement, 8" didn't cut it so I simply used an old lampshade cord which had a white line on the hot side of the cord so it was an easy install. The Hammond 193M is twice the size of the 193L which most folks are using to isolate each component. With a component hookup , it's preferable to have the choke as close to the component as possible so you would have your component plugged into the top outlet and a PE in the lower outlet. Ideally you'd use an IEC Liberator cord on the end of the component and the choke plugged into that. I hope I have this right but if I don't, you have a general idea and experiemnting with location is half the fun anyways.Hope this layman's explanation helps. Cheers,RobinHi Robin: I just wanted to check something...that being where you said that the longer wiring being the hot (AC plugs wide pin). Every receptacle in my house is wired so the "narrow" blade is the HOT and the wider blade is "NEUTRAL". I am not questioning your wiring hook-up...I just wanna know if my house is wired correctly...that being wide prong is "neutral" and narrow prong being "hot".Hope someone can clear this up for me! Thanks, Huck
. Now, it's even better to my ear. I'm no technical person, but i trust my ear. I believe my system can be better if i can add more PE + chokes...
Quote from: michaelv on 6 Mar 2008, 05:15 pm. Now, it's even better to my ear. I'm no technical person, but i trust my ear. I believe my system can be better if i can add more PE + chokes...Michael, I agree.
