Canceled
0 Members and 1 Guest are viewing this topic. Read 3233 times.
ebag4
Canceled
« on: 3 Feb 2008, 05:32 pm »
For Sale:
41Hz Amp 4 with Jensen PIO coupling caps.  Connectors are Cardas Rhodium.  Power to the amp is supplied by 2 12V 5ah SLA batteries, I have played this unit over 12 hours at a time and have not run the batteries down, they will recharge easily by the next day.  The charger is the Batterymart 12V 1 Amp charger with charge and charged LEDs.  Steel case (black) with 3/8” black Aluminum front plate (1/8” silver Aluminum front plate included as well), case dimensions are approximately 10”Lx9”Wx4”H.  Both + and – from charger are disconnected at the entry point into the amp when switched on.  Switch amp on it plays, switch it off it charges.  No additional LEDs to negatively impact sound, the only LEDs are on the charger, red when charging, green when charged, and no LEDs when playing.  Amp is rated at 30 wpc, here are the specs from the 41Hz website:
This amp is based on the Tripath TA2050 chipset. Datasheet data indicates very low THD+N for this single supply amp. It is intended mainly for 8 ohm loads but 4 ohms loads can be used with reduced supply voltage. Nominal maximum supply voltage is 20 to 32 volts, including battery power.
·   Output 2x30W @ 8 ohms / 0.007% THD+N / 30V, 2x50W @ 3% THD+N
·   Single supply, bridged outputs
·   Onboard power supply with rectifier and  2 X 10.000 uF bulk capacitors. Add a transformer.
·   Very quiet two stage +5V regulator on board
·   Power FET chip mounted on bottom of PCB for mounting towards casing bottom or back
·   Output relay to protect speakers
·   Quality components. Mostly surface mount.
·   Double sided, double weight copper PCB
·   Footprint 50 x 125 mm, height 50 mm
·   Status outputs (LEDs) for mute, fault, temperature warning
·   Typically 90% efficiency; low heat, moderate heat sink requirement
Magnet wire was used for the entire 6” internal signal path, the input form the RCA are wired to the board directly via the silver leads of the Jensen PIO caps.
Specs for the connectors:
CCGR SCardas/Colver binding post, short billet Copper posts, Rhodium over Silver plate. Billet Copper nut, Gold plate. Glass filled nylon insulator.
GRFA L ThickLong RCA female, non- magnetic, eutectic Brass, Rhodium over Silver plate. Thick Brass nut, Gold plate.
This unit is dead quiet, runs completely cool, and has good dynamics and control over drivers.
Asking $400.00 plus shipping and 3% paypal.  At this price you are basically paying for parts.
May be willing to do a partial trade for a motherboard/CPU(over 2G please)/and Ramm or some nice EL84s(quad), 12AT7s(pair), or 12AX7s.
Thanks for looking!
« Last Edit: 24 Mar 2008, 04:23 pm by ebag4 »
ebag4
Ed
« Last Edit: 25 Feb 2008, 07:51 pm by ebag4 »
jrebman
Ed,
After all that? :-)
Do I smell a Jolida 102B?  That tube complement looks awfully familiar :D
-- jJim
ebag4
Hi Jim,
Yes you do!  I actually just sold a stock 102b and I am currently running a factory modded 102b.  I haven't had a ton of tubes through here but what I have had just didn't do it for me, that was until the mighty EL84 made it's presence known.  I am a very happy camper at the moment! :thumb:
ohenry
I can tell you that the amp4 with Jensen caps is a great little t-amp. I made one and thought the tone was better and the high frequencies were smoother than the lower powered amp3's that I've assembled.  The bass was incredibly good in all aspects.  You couldn't make this amp for less than Ed's asking price.   I believe those caps cost >$120.  The amp4 is VERY challenging to assemble and has frustrated some experienced builders (not that I would know). :oops:  If you want a taste of serious tripath on the cheap, here it is.
ohenry
Hi Jim,
Ed, I have a single-ended EL84 amp and recently bought some used Amperex with "D" getters just to see what would happen.  Boy, are they a cut above the other EL84's I've heard.  I got these from a guy that sells pulled quads from old Hammond equipment and they weren't very expensive.  If your amp requires matching to the hilt, I wouldn't bother.  But if not, check out epay and look closely at the photos and codes for the right version.
jrebman
Ed,
I have a factory modded one as well -- picked it up as a dealer demo with 10 hours on it.  I just put it back in the box today as I switch equipment racks in the office.  I have a quad of the TAD EL84 STR, and another of the cryoed JJ Teslas that I will be getting to soon enough.  A bunch of 12AT7s and 12AX7s and 5751s as well.  A real little tank of an amp -- I was shocked at how much it weighed when I pulled it out of the box for the first time -- lots of iron there.
I read the comments of an EL84 fan some time ago with respect to the JJs -- saying that he couldn't be in the same building with them as they were breaking in, but then they turn into Mullards.  Don't know how true that is, but that's why god invented 8 ohm 50 watt resistors.
-- Jim
ebag4
Thanks for the props Henry!  I will keep a look out for the Amperex with "D" getters.
Jim, the stock 102b I just sold had the JJs in it, I thought it sounded very good, unfortunately I have no real basis of comparison for the sound of various EL84 tubes.  I guess that is why they made the net and tube reviews!
ebag4
Monthly bump.  Also considering computer mobo/cpu(over 2G please)/ramm in partial trade.
ebag4
Bump.
Any interesting trades??  Make me an offer!
