FS - POWERVAR ABC-1200 11 - SOLD!!!!
0 Members and 1 Guest are viewing this topic. Read 1039 times.
Sonny
« on: 31 Jan 2008, 06:46 pm »
Hi there, I have a black Powervar ABC-1200 with six outlets.
I now have a dedicated line and no longer need this...
Interested, please let me know.
I am in Bay Area
Tuan
Here are the specs:
The multi-stage POWERVAR incorporates three stages of conditioning using the following components.
1. Low impedance isolation transformer (toroid). Does not limit current!
Isolation transformers help eliminate common mode and normal mode noise or voltage disturbances as permitted by the electrical code (bonding to the ground wire to permit voltage disturbances a clear pathway to the earth and away from your electronics). Both and LOW and high voltage (amplitude) transients are shunted away from your fine electronics to ground.
2. High quality AC noise filter. A filter removes higher frequency, low energy, voltage or noise disturbances.
3. Surge diverter. A diverter takes all high voltage transients and diverts them safely away from your precious electronics.
SPECIFICATIONS:
• Used. Rated 8-9/10.
• 43 pounds! 43 pounds! 43 pounds!
• 12 (TWELVE) amps of TRUE AC power protection and cleaning
• Master power switch with breaker and six quality NEMA
receptacles
• Indestructible barring direct lightning strike.
• Fits on almost all audio rack shelves (H x W x D IN)
5.60 x 11.15 x 16.10
• Eight foot power cord that can easily be replaced if
desired
« Last Edit: 4 Feb 2008, 05:59 pm by Sonny »
Sonny
Re: FS - POWERVAR ABC-1200 11 - $200 plus shipping! (BLACK)
« Reply #1 on: 1 Feb 2008, 02:15 am »
evening bump... :thumb:
Sonny
SOLD!
