0 Members and 1 Guest are viewing this topic. Read 3645 times.
From what I recall the D-200 has a beefier power supply than the D-100, otherwise both use the same UcD amp. Dusty?The ability to drive Logans well was one of the reasons why I bought D-200s.
I thought the D100 uses UcD180, while the D200 uses UcD400 modules, no?
QuoteI thought the D100 uses UcD180, while the D200 uses UcD400 modules, no?Both models are based on modifed UcD400 modules.
D-200 produces more power at 2 ohms than D-100, but this doesn't really matter...the speaker is only around 2 ohms at high frequency. There are no problems running various ML models with either D-100 or D-200.
I know Stereophile tested the D-100, and the results were pretty good - 100W at 8, 200W at 4, 300W at 2 Ohm. Does the D-200 scale like that?
