0 Members and 1 Guest are viewing this topic. Read 6990 times.
I will say that I personally prefer to have my music NOT on the device itself.
I will say that I personally prefer to have my music NOT on the device itself. I run a separate server and can add storage capacity as I need to. To me, that's the one big drawback with a 1 box solution. When the disk is full, how do you add more?
Quote from: bpape on 31 Jan 2008, 04:25 pmI will say that I personally prefer to have my music NOT on the device itself. I run a separate server and can add storage capacity as I need to. To me, that's the one big drawback with a 1 box solution. When the disk is full, how do you add more? When the Olives are full, an external hard drive can be connected.
Quote from: maxwalrath on 31 Jan 2008, 07:22 pmQuote from: bpape on 31 Jan 2008, 04:25 pmI will say that I personally prefer to have my music NOT on the device itself. I run a separate server and can add storage capacity as I need to. To me, that's the one big drawback with a 1 box solution. When the disk is full, how do you add more? When the Olives are full, an external hard drive can be connected.Yes. 1 External hard drive can be connected. What if you need more?Bryan
Quote from: bpape on 31 Jan 2008, 07:44 pmQuote from: maxwalrath on 31 Jan 2008, 07:22 pmQuote from: bpape on 31 Jan 2008, 04:25 pmI will say that I personally prefer to have my music NOT on the device itself. I run a separate server and can add storage capacity as I need to. To me, that's the one big drawback with a 1 box solution. When the disk is full, how do you add more? When the Olives are full, an external hard drive can be connected.Yes. 1 External hard drive can be connected. What if you need more?BryanThere are 2 USB ports on the back of the Olive.... two external hard drives can be connected.
Hi,Anyway if you are in the market I wanted to point you back to the Squeezebox website (no connection) because they have a new product similar to SB3 but now interface display in on the remote which has a 2" lcd and it looks like controls very similar to an iPod.
Particularly, if SB sites forum's are correct and the hand held will work with other existing SB's and transporters "to be bought later."
