0 Members and 1 Guest are viewing this topic. Read 5720 times.
a sound space beyond 60 degrees
tschanrm, I'm slightly confused by your OPSODIS descriptions when you talk about in-phase vs out-of-phase and some degree of XTC. Did your setup implement explicit cross-talk cancellation, or did you simply use FIR filters for xovers and spread the drivers? If you did use explicit xtc, then I guess I'm confused by your experiments with in/out of phase arrangements.I'm very interested in the the OPSODIS approach based on my relatively brief experiments with the Ambiophonic software (both the audiomulch chain and the Choueiri filters provided with jace), although my main speakers aren't particularly well suited to it.
tschanrm - Just to comment on your Polk Surround Bar testing....SDA, Stereo Dimensional Array was not designed, originally, as a 360 source of sound reproduction. That was much much later.The SBar isn't dependent on the sidewalls for the surround effect, like the Yamaha, but that's a pretty wide room for that loudspeaker. I don't think you had to spend hours trying to tweak it but thanks for taking the time to do so The SDA surround channels definitely work but in the testing I've done with them, I had to run the rear channels +3-5db to get the surround to kick out a bit. The best demos for me were ones that really go out of their way to give the surround channels a workout. Otherwise, I agree, it's hard to get a feel for it. Does it replace a bonafide HT? No, that's silly.There are two more versions on the market now, one of which includes DSP room optimization. I wish they had come out with either one of these models first, but I'm just an internet dude. You can check them out on the website if you're at all interested. I don't know where you're located but if your a Marylander, you're more than welcome to come on over for a demo.....I can promise you'll leave with a full stomach and at least some good music to look into Mark
