Grounding question for Cornet 2?
0 Members and 1 Guest are viewing this topic. Read 1325 times.
Bill Epstein
« on: 29 Jan 2008, 01:41 pm »
In preparation for a new MM magnet cart, I 've removed the Cinemag step-up from the inputs.
The combo AC switch/fuse module is grounded to PS Earth.
The RCAs are isolated from the chassis.
The board is isolated from the chassis.
The separate ground lug terminal for TT ground is in contact with the chassis.
Do I need to connect the ground lug to anything on the board?  :scratch:
hagtech
Re: Grounding question for Cornet 2?
« Reply #1 on: 29 Jan 2008, 06:37 pm »
The ac connector ground lug connects to gnd lug on chassis.  A second wire connects the lug to a ground terminal on the board.
jh
Bill Epstein
« Reply #2 on: 30 Jan 2008, 02:13 am »
Ohhhh, safety ground....I knew I forgot something!  :oops:
