Big elecrical spike
0 Members and 1 Guest are viewing this topic. Read 1380 times.
PMAT
Big elecrical spike
« on: 26 Jan 2008, 02:54 pm »
How do I fix this? When I turn off my bathroom fan, a huge-ass pop goes through my home theater system. I replaced the switch but it still sounds like a .22 rifle shot. I have a large Monster Cable ac surge protector but it doesn't stop it. I called them and they say the unit is not designed to stop spikes.
HAL
Re: Big elecrical spike
« Reply #1 on: 26 Jan 2008, 04:11 pm »
Sounds like the audio system is on the same circuit as the fan.  Do you have another AC circuit in the room that could be used to power the system?
PMAT
« Reply #2 on: 26 Jan 2008, 06:19 pm »
No, unfortunately I don't.
HAL
« Reply #3 on: 26 Jan 2008, 06:38 pm »
You might try and demo a Price-Wheeler Brick Wall surge supressor.  The PW2RAUD is a high current version that should run an entire audio system, without mechancial hum from the inductor.  The other unit would be a ZeroSurge equivalent.
www.pricewheeler.com
www.zerosurge.com
