Re: Tube Preamp
0 Members and 1 Guest are viewing this topic. Read 1000 times.
avahifi
    • http://www.avahifi.com
Re: Tube Preamp
« on: 25 Jan 2008, 01:54 pm »
Hey Ray, I have a new basic Transcendence Eight vacuum tube preamp available.  No options, line only.
I will let you "borrow it" with you Visa or MC info supplied here to "hold hostige".  I won't charge it out unless you keep it.  $1099.00.
Assuming a prompt return all it will cost you is round trip postage.
Frank Van Alstine
guest1632
  • Guest
Re: Tube Preamp
« Reply #1 on: 25 Jan 2008, 05:26 pm »
Frank Van Alstine
Hi Frank,
Well, frankly speaking, if I were me, and once I know the funds were there, I'd get the Ultra T7 and be done with it. On both preamps, what is the output impedance of either one? That too is a dependent factor.i just might take you up on your offer. There is a check that is supposed to clear in the next week or so, then we can talk turkey.
Ray
