3DCC
0 Members and 1 Guest are viewing this topic. Read 3393 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
3DCC
« on: 24 Jan 2008, 10:57 pm »
Coming soon to Pittsburgh...
AvFan
Re: 3DCC
« Reply #1 on: 25 Jan 2008, 03:59 am »
Very nice looking speaker.  Is this center channel going to be used with the Garnets?  If so, which tweeter would you use in the Garnet?
mateo
Re: 3DCC
« Reply #2 on: 25 Jan 2008, 08:17 am »
Nope, it matches the 3Ds- http://www.selahaudio.com/id134.html
tkam's a pretty lucky guy...
Rick Craig
  • Selah Audio
Re: 3DCC
« Reply #3 on: 25 Jan 2008, 03:58 pm »
It was designed to go with the 3D that we showed at the 2006 RMAF show. With the Garnet I haven't designed a companion center channel but that certainly could be done. Right now I'm working on one that matches with the Galena and SSR.
klh
Re: 3DCC
« Reply #4 on: 25 Jan 2008, 07:48 pm »
Rick or TKAM...
How does the 3DCC sonically mate with the 3D? Just curious since one is obviously open baffle while the other is enclosed (sealed?). Do you notice a difference?
Also, how's the off axis reponse (V an H)?
BTW, looks beautiful as usual :). Oh... what's the plan for surrounds?
Rick Craig
  • Selah Audio
Re: 3DCC
« Reply #5 on: 25 Jan 2008, 10:18 pm »
Rick or TKAM...
Also, how's the off axis response (V an H)?
It's a sealed box voiced to match the 3D. Obviously the midrange radiation pattern is different but for this system a direct radiator was more practical in terms of placement. The horizontal off-axis response is better than most any horizontal MTM because we used 5" woofers with a large ribbon. Spacing is tighter between the woofers and the large ribbon gives us a lower crossover point. The off-axis response is very good but of course more narrow vertically with the larger ribbon; however, I did some tricks with the crossover to optimize both the vertical and horizontal coverage.  :thumb:
klh
Re: 3DCC
« Reply #6 on: 25 Jan 2008, 10:53 pm »
Sounds good! Hopefully we'll get his response after he's had a chance to set everything up.
tkam
    • Head-Case
Re: 3DCC
« Reply #7 on: 29 Jan 2008, 03:06 pm »
Looks absolutely fantastic Rick, I think it's going to be a spot on match for the look of the 3D's and I'm sure it'll sound equally as good ;).
