0 Members and 1 Guest are viewing this topic. Read 9711 times.
Nicely done Brad. So, do you have plans to add a level control either before or after the amps so you can match the levels?
with a level control I imagine every equipment reviewer on the planet would need one of these!
BTW: I was reading another article on ABX testing that was set up for level matching with a mute setting and probe points for matching with a volt meter rather than an SPL meter. A cool feature, but not something I'm going to put into this right now. Although there's room on/behind the front panel for a panel mount volt meter.
However, I don't understand the need for dummy loads in the switch box. Those could be dispensed with and some money saved.
I have done it both ways and the interesting thing about matching voltage into a resistive load is that depending on the real world impedance of the speakers and the Zout of the amp/it's ability to act as a voltage source the SPL's don't always match. Of course this is an interesting way to see how well an amplifier deals with real loads.
Audio reviewers aren't interested in doing blind comparisons (for reasons that should be obvious).EDIT - just realized this is the lab circle. Mod - please censor this post if it's inappropriate.
You don't happen to have a good source of inexpensive attenuator switches (unpopulated), do you?
hey bradjudy, seeing as how we almost inadvertently got into it in a different forum (just a simple misunderstanding folks nothing serious) i thought i'd drop a line here to say WOW i'm jealous! i actually went online to buy an amp switcher and found this ugly thing...
