Castanet as Buffered Linestage
0 Members and 1 Guest are viewing this topic. Read 1354 times.
flocchini
« on: 21 Jan 2008, 07:47 pm »
"For the truly adventurous, the Castanet can be used as a linestage (buffered volume control) to add a little SET magic into your system."
I don't know if I qualify as truly adventurous but I did put together a phono plug to RCA (well BNC anyway) adaptor - plugged it into the High jack and am running my amps/speakers. The 2.6dB gain is really all I need. Sounds really, really  good. All the comments I made regarding the Castanet as a headphone amp apply here. Tight bass, great detail and nice highs. I'll clean up my interconnects. All I had available was surplus 50 ohm BNC terminated lab interconnects. My amps are at the speakers so I need 20 ft interconnects. I'll get some more traditional interconnect cable and build some new ones. Eventually I may bypass the Castanet volume control and use a remote control stepped attenuator. Bottom line is that I am impressed and will continue the experiments. Jim - a truly versatile product. :P
Bob
Theo
Re: Castanet as Buffered Linestage
« Reply #1 on: 21 Jan 2008, 08:18 pm »
It's great news that it also sounds good as a buffered linestage.  That was one of my intention to build a Castanet - I have a selector box and I wanted a piece that can double as a headphone amp as well as a linestage.  It will take another couple weeks to finish my Castanet build.  Now I'm too busy having fun with my newly built Cornet2.
