EM7 - tailoring the highpass inputs
0 Members and 1 Guest are viewing this topic. Read 1919 times.
jman66
« on: 20 Jan 2008, 10:51 pm »
The EM7 comes through with a cap on the 2nd (or 1st however you look at it) set of inputs, which highpasses 100Hz on up.
Is there a way to determine what other value caps can be used to alter the highpass point?
jeffreybehr
Re: EM7 - tailoring the highpass inputs
« Reply #1 on: 21 Jan 2008, 07:04 am »
The input-load resistor is 150K-Ohms.  Using the standard hi-pass-filter formula of F = 159155/RC, where F = Filter (-3dB) Point in Hz, R = resistance in Ohms, and C = capacitance in microFarads, the existing calculation is F = 159155/(0.01*150,000), = 106Hz.
Plug any values for C you want in the formula and Bingo! you have a new number.
jman66
« Reply #2 on: 21 Jan 2008, 10:35 am »
Many thanks!
Roger A. Modjeski
« Reply #3 on: 25 Jan 2008, 05:08 am »
Jeffrey,
Thanks for helping out on the questions while I dig myself out of all these tubes for which I am developing new applications. I am leaving no reasonable stone unturned.
