0 Members and 1 Guest are viewing this topic. Read 60582 times.
BTW, Rudolf, how are you liking the Peerless SLS 12"?
Somehow the SLS seem to be the stamped frame drivers with the build quality of a good cast frame driver. Their venting system is light years ahead of those Visatons you are mentioning. The W300 does not even have venting to speak of. Xlin (8mm) is well ahead of the Visatons (5 mm) too. Depending on the Xover frequency you may want to damp the frame legs a bit.If you look around you will see the SLS series used in dipoles all the time. I don´t remember a dipole project with the Visaton W300 series.BTW: I am amazed how fast you have been moving from a "no compromise accepted" attitude to the lowlands of value drivers. . It´s a lot more fun around here.
What do you think instead of the Eminence Beta 12A2*?I's really looking good in my sim.
Quote from: Telstar on 25 Mar 2009, 02:15 pmWhat do you think instead of the Eminence Beta 12A2*?I's really looking good in my sim.Sorry, I don´t know any longer, what the actual boundary conditions of your project are. Baffle size, efficiency, other drivers? You seem to be fixed to max. efficiency? Or is it max absolute SPL? Could you give a brief summary, from where I could better judge, what the actual goals are?Rudolf
