SB3 - Switching Between Multiple Servers (Mac or PC)
0 Members and 1 Guest are viewing this topic. Read 1254 times.
John151
I am running two servers, and two players.  I occasionally want to switch the server that the player is connected to.  The only way I have found is to unplug the player, and go through the set up process.  Is there a better way (please say yes)?
Thanks in advance.
GBB
Re: SB3 - Switching Between Multiple Servers (Mac or PC)
« Reply #1 on: 19 Jan 2008, 05:26 pm »
Hold down the left arrow button on the remote for a few seconds and it will eventually take you to the menu for setting up the network.  You need to hold it down continuously until you see the right screen.  You'll be able to chose the server at that point.
---Gary
John151
« Reply #2 on: 19 Jan 2008, 08:26 pm »
Yep, that's the ticket.  Thanks for the help!
