Is it OK to use metal standoff for Cornet2?
0 Members and 1 Guest are viewing this topic. Read 1289 times.
Theo
« on: 17 Jan 2008, 08:43 am »
Is it safe to use metal standoffs to mount the Cornet2 board to the chassis?  Are any standoff mounting holes connected to any part of the circuit on the circuit board?  I ask because I found continuity between the standoffs and the R200 leg after mounting the board to the chassis.  Would that continuity cause a short?  I want to make sure before I connect power.  Thanks.
hagtech
    • http://www.hagtech.com
Re: Is it OK to use metal standoff for Cornet2?
« Reply #1 on: 17 Jan 2008, 05:19 pm »
It is ok to use metal standoffs.  But you'll want to use an insulating washer to make sure you won't break through the solder mask and short to the ground plane.  I like the nylon standoffs because they seem to have better anti-microphony damping properties.
jh
Theo
« Reply #2 on: 17 Jan 2008, 05:28 pm »
jh
Thanks Jim.  I'll just go get some nylon ones.
