0 Members and 1 Guest are viewing this topic. Read 6012 times.
Having a lot of fun reading about and trying various power "treatment" devices.It seems that there are three basic types or treatments:1) Power Balancing 2) Power Stabilization3) Power Cleaning/FilteringExamples of each would look like this:1) Power Balancing - Transformer based systems like BPT2) Power Stabilization - Systems like ExactPower and PS Audio's P10003) Power Cleaning/Filtering - Systems like Monster 3500, BPT's CPC, and others.Now of course many have combined systems ...
My amps are plugged into the wall, my sources are into the PP600.
Dejan, I agree with you with the PS Audio stuff on amps, but I must disagree on source equipment.In my system I have no trouble with dynamics at all. My amps are plugged into the wall, my sources are into the PP600.As always YMMV
I was referring to loss of dynamics with quite a few power treatement devices in circuit.
QuoteI was referring to loss of dynamics with quite a few power treatement devices in circuit. Hi Dejan,I recently noted such a loss of dynamics and detail when I plugged my Jeff Rowland 8T amp into the AR Senior w/ground. The amp sounds better plugged directly into the wall.I was surprised as the DeZorel has worked well with my Mesa Baron tube amp and the Norh Le Amps. Does a massive power supply and plenty of capacitance (640,000uF) render the amp relatively immune to line noise? Or ...
Power amps need clean power, too. ...
My own personal preference is to use balanced power on source and preamp, and a filter on the amp...
I agree with this, but I also think that different power solutions will have different effects on an amp that may not justify the tradeoffs (depending on tastes and preferences). My understanding is that if you put a transformer into the AC path, you will lose some speed, so solutions like balanced power will result in loss in dynamics. Phil
Phil, it is my belief that your understanding is flawed, at least from what I`ve read and more importantly from what I`m experiencing with my 2 Butler Audio 3150`s plugged into my BP2.5 w/4 Bybee`s fully modified also. I also have everything else plugged into this balanced power conditioner and I can assure you that I have no lack of dynamics. In fact, it`s just the other way around..
My personal experience has been that putting a balanced power conditioner on my amp has reduced speed and dynamics. When I first got interested in using power conditioning products a few months ago, I bought two balanced power conditioners (Blue Circle MR800 and MR1200). I put my cdp and preamp on the MR800 and my amp on the MR1200...the MR1200 handles a max of 1200W, and my amp has a max draw of 600W, so there was no issue with maxing out the headroom on the MR1200. Initially, I was shocked...the entire ...
Power amps need clean power, too. This "plugging straight into the wall" thing is a misconception brought about by the use of inadequate filters and subsequent loss of performance.. ...
Hi DVV,Thanks for the suggestion...I would certainly like to try it, although at this point, I'm very happy with the MR800's performance on my source and preamp. It looks like the DeZorel is more than I need for the 70W drawn by source/preamp, but I'd definitely like to experiment more with power conditioning as it is used on a power amp. As noted in my previous message, that's where I've found more weakness than improvement from balanced power conditioning.Phil
