Behringer DCX2496 x-over mods for all the CS2 owners!
0 Members and 1 Guest are viewing this topic. Read 1461 times.
ASi_TEK
  • NO LIMITS!!!
    • www.asi-tek.com
ASi Teknologies is now offering superb value, high performance improvements to your Behriger DCX2496 active crossover.
This crossover is most often used in the Emerald Physics CS2 loudspeaker system currently in the audiophile marketplace.
Introduction:
The Behringer DCX2496 is the processor needed when it comes to line level
crossover applications (its done in the digital domain!!) and some light system
room equalization as well. The downfalls of this commericial peice is the lack of
quality of parts used within.  We have designed some really great modification
improvement packages to take the parts quality up to the highest levels in the
power supply, input stage, DSP stage, analog output stage , and lowering jitter in
the critical DSP section as well to make the processing work much better. The end
results now is a much more wider, taller and deeper sounding crystal clear,
dynamic and resolute performance that will make your application, or more
specifically the Emerald Physics CS2 loudspeaker system really sing.  Everyone
who owns the CS2's needs this mod package to really experience the most out of
those speakers! We have designed this package to be turned around in 1 weeks
time! Contact us or order online and we will respond with shipping info.
Pricing:
DCX2496 Modification Package (without clock)
$495 Installed/Shipped, Send your unit in for mods
1 Week Turnaround
DCX2496 Modification Package (with clock)
$795 Installed/Shipped, Send your unit in for mods
1 Week Turnaround
New Modified Behringer DCX2496 $1195 Shipped
10 day turnaround
DCX2496 Modification Descriptions
Power Supply, Input stage, and Output Stage Modifications-
We replace critical capacitors and diodes in the SMPS power supply with Ultra Low Impedance
Rubycon capacitors and ASi ultra low impedance silver diode bridges. These new unique diode
bridges give the unit superior speed and bass that no other diodes being used on the market
are giving, due to their extremly low impedance. The Rubycon caps are very  fast reacting
capacitors. We replace the stock smoothing cap in the power supply with the exceptional Jensen
4-pole version which provides increased performance over any of the best 2-pole design on the
market. The typical 2-pole design pushes noise to the HF portion of the signal, the
Jensen blocks noise and decouples and acts as also filter circuit. The numerous input and output
stage opamps are replaced with the best sounding, most transparent versions currently on the
market and all the coupling/decoupling capacitors used are replaced with the Rubycon Ultra Low
Impedance caps. This upgrade removes glare, removes grain, removes the stock high frequency
problems, and adds speed, dynamics and resolution and openess.
DEXA Reference Clock Upgrade-
We add a reference quality jitter reduction circuit called DEXA clock to replace the stock
24/96khz circuit reference crystal oscillator for a drastic reduction in jitter in the digital
circuits. Expanded soundstages, additional low level detail, focus and resolution are
examples of this major mod component. Please allow the unit approximately 100 hours
to break-in with this clock. We wire the clock into the circuit with silver wire cable and
cotton tubing for the best digital connection.
Here is a direct link to the website for purhcasing: http://www.asi-tek.com/behringer.html
Please visit www.asi-tek.com to check out our new website!
Please email, post here or PM regarding any questions. We look forward to improving your sound!!
« Last Edit: 16 Jan 2008, 08:25 am by ASi_TEK »
