N1P upgrade for hybrid preamps
0 Members and 1 Guest are viewing this topic. Read 1762 times.
Ernest
« on: 14 Jan 2008, 06:54 pm »
Can this upgrade be performed on a Transcendence 7 SLR preamp?  If so,
what would it cost?
Ernest Obusek
Wayner
Re: N1P upgrade for hybrid preamps
« Reply #1 on: 14 Jan 2008, 10:42 pm »
I think it needs to be in the larger full size case.
Wayner
avahifi
    • http://www.avahifi.com
« Reply #2 on: 16 Jan 2008, 08:35 pm »
Correct, we need to start with the newer 17" wide case for adequate thermal performance.  The 6N1P tubes run quite hot, as does the the necessary regulated heater supply (20 watts of heat sink on that supply IC alone).
Frank
Dan Kolton
« Reply #3 on: 17 Jan 2008, 12:10 am »
It's still worth it.  Frank had to put my Ultra DAC into the larger case to upgrade to the 6N1Ps, but wow, you should hear the dynamic range now!
Ernest
« Reply #4 on: 17 Jan 2008, 09:34 pm »
OK, then what would the cost be to have this upgrade including putting the preamp in the larger case?
Ernest
avahifi
« Reply #5 on: 21 Jan 2008, 12:29 pm »
Its more cost effective to simply trade the T7 in on a new unit.  Call me for a price quote.  651-330-9871
Frank
