Wadia Doc and 4G iMod?
0 Members and 1 Guest are viewing this topic. Read 2215 times.
t-head
  • 'I am sure that I am sure of nothing'
« on: 13 Jan 2008, 04:33 pm »
Hi Vinnie,
Thanks for checking out my unit...
Now, I have been reading about this new Wadia thingy...
Since your mods for our ancient 4Gs changes the dock connection, will our 4Gs be able to play out of the Wadia?
t (Richard)
Alwayswantmore
Re: Wadia Doc and 4G iMod?
« Reply #1 on: 14 Jan 2008, 01:01 am »
I won't speak for Vinnie on his part of the mod, but if you follow all the links, Wadia has been pretty clear that this unit is intended for all current generation units. This means that even G5 video units will play music, but the thumbwheel navigation does not work. So it looks like the best candidates will be Classics and beyond.
Vinnie R.
    • http://www.vinnierossi.com
« Reply #2 on: 14 Jan 2008, 02:14 am »
Hi Vinnie,
t (Richard)
Hi Richard,
Kent is correct... Based on what has been posted, you will not be able to use a 4G iPod (or iMod) with the Wadia.
Best regards,
Vinnie
