How long can my USB cable be?
0 Members and 1 Guest are viewing this topic. Read 1411 times.
Big Red Machine
« on: 13 Jan 2008, 12:53 am »
Squeezebox issue:
I want to move my hard drive away from the action because it is noisy.  I can put my laptop right next to my sweetspot on a table and I can surf, etc when I listen to tunes.  So if the hard drive is plugged into the laptop, how far away can I put it before the signal degrades via the USB cable?
GHM
Re: How long can my USB cable be?
« Reply #1 on: 13 Jan 2008, 01:04 am »
You can use an optical USB cable from what I've read and run lengths longer than 20 feet without issue. I wouldn't go much further than 15 feet using the basic USB cable.
Their not cheap, but some guys swear by them..http://industrialcomponent.com/opticis/optusbext.html
ooheadsoo
« Reply #2 on: 13 Jan 2008, 01:26 am »
Just use an active repeater (usb hub that requires power.)  Each cable run should be no more than 15ft or so, like GHM stated.  There's a spec out there for USB but I forget exactly what it is.
WGH
« Reply #3 on: 13 Jan 2008, 01:31 am »
I run 30' with no problem, but you need a active extension/repeater USB cable.
Monoprice is the best place to get these, their quality is very good too.
http://www.monoprice.com/home/index.asp
