Looking for VTL Deluxe preamp info
0 Members and 1 Guest are viewing this topic. Read 7368 times.
BillB
« on: 10 Jan 2008, 03:33 am »
Anything will help, especially what tubes are supposed to be installed.
I picked one up today and I love it so far but I have read it has 12au7s in it and mine has 6922s which are not compatible as far as I know. I don't know if someone modified it to use them or not.
Again, any info would be greatly appreciated...oh yeah info on the outputs as well.
Thanks!!
steve k
Re: Looking for VTL Deluxe preamp info
« Reply #1 on: 10 Jan 2008, 03:54 am »
According to the schematic in the VTL Book, The deLuxe uses (2) 12AX7's and (1) 12AT7 in one channel so you can double that for both channels. This includes a phono stage.
steve
BillB
« Reply #2 on: 10 Jan 2008, 12:59 pm »
There are a total of 5 tubes in it.
A 12ax7 far left which is for the phono, a big gap then another 12ax7, then 2 (in mine) 6922s, and a single 12at7.
(PS, thanks for the help)
Here is a pic of mine:
steve k
« Reply #3 on: 10 Jan 2008, 04:37 pm »
I would think the 6922's should be 12AX7's. That would give you (2) 12AX7's per side plus one 12AT7. There are no 6922's shown in DAvid Manley's schematic.
BillB
« Reply #4 on: 10 Jan 2008, 04:41 pm »
Thats what scares me and I cannot tell if someone modded it to use 6922s or not as I don't have the schematic.
It works with the 6922s so I assume someone modified it, but I think it would take more than just the 9 pin swap to make it work.
