Need Manual For Adire Audio Rava Sub - Help??
0 Members and 1 Guest are viewing this topic. Read 1403 times.
tlarwa
« on: 6 Jan 2008, 11:51 pm »
I just bought a minty Rava ... but it has no manual.  Does anyone have one they can copy or scan for me?
Tom
Re: Need Manual For Adire Audio Rava Sub - Help??
« Reply #1 on: 7 Jan 2008, 01:13 am »
I have one.  What amp do you have in it?
tlarwa
« Reply #2 on: 7 Jan 2008, 02:56 am »
There's no model # or name on the amp, but it says that it is 450W.  It is selectable between 220V/110V and has phase, level and crossover adjustments, as well as line and speaker level inputs.  I hope this helps!  If you can make a scan of the manual, or have it to send electronically, my e-mail is [email protected].  If you need to copy and mail it, I'd gladly reimburse you for any costs.
Tom
« Reply #3 on: 7 Jan 2008, 02:23 pm »
Tom, if you send me your address I'll make a copy and mail it off to you.
tlarwa
« Reply #4 on: 7 Jan 2008, 04:03 pm »
Someone sent me a link to the manual on this site:
http://web.archive.org/web/20030415065105/www.adireaudio.com/Files/RavaManual.PDF
Does this look like the same manual you have?
Tom
« Reply #5 on: 7 Jan 2008, 09:19 pm »
Yes...I think.  I don't have it here.  The cover is the same.  I believe the only other Rava was a Rava SE which had a Hypex 200watt amp in it.
