For Sale - Audio Metallurgy GA-2 Interconnects
0 Members and 1 Guest are viewing this topic. Read 1483 times.
martinr
« on: 6 Jan 2008, 09:04 pm »
These are .75 Meter interconnect cables - these are the GA-2's not the GA-0.  I purchased new on Audiogon auction for around $80.00 approx. 8 months ago.  Will sell shipped and paypalled within the U.S. for $45.00.  Good cable for the money - bested a pair of DH LABS silver sonics I had, last pair I saw sold on Audiogon for over $100.00  Selling due to upgrade to a more expensive cable.
 aa
- Martin
bump
« Last Edit: 9 Jan 2008, 02:25 am by martinr »
Big Red Machine
Re: For Sale - Audio Metallurgy GA-2 Interconnects
« Reply #1 on: 6 Jan 2008, 09:53 pm »
real quick, what is difference from the zeros?
martinr
« Reply #2 on: 6 Jan 2008, 10:06 pm »
- excerpt from manufacturer on zeros construction:
"This cable starts with 2 single runs (3 for the balanced version) of our phenomenal gold plated wire, sandwiched between 2 identical, flexible, medium strength magnets! There is no insulation of any kind on either run, and nothing seperating them but air. The only contact made with the wires is a small amount of adhesive holding the wires in place during assembly and a small cross section of the magnets. This is a very complex design that requires no batteries, capacitors or resistors to achieve a perfect signal flow. As the current passes through the signal wires in the middle of the magnets, it creates it's own electrical magnetic field surrounding the wires transferring the signal. This field is the perfect shield that really has almost no interaction with the signal (not true with active...think batteries...shield)."
- excerpt from manufacturer on GA - 2 construction:
"The GA-2's are the latest addition to our line of interconnects! They feature our 20 gauge, Teflon encased, silver-plated wire in a triple linear configuration. The whole cable is then finished off with an outer layer of super-tough KEVLAR . This cable is EXTREMELY flexible and so tough, you can't cut it with a pair of quality scissors. You will not be disappointed."
- These have the Neutrik ProFi Professional gold plated RCA connectors
Big Red Machine
« Reply #3 on: 6 Jan 2008, 10:10 pm »
Thanks!!
martinr
« Reply #4 on: 9 Jan 2008, 02:26 am »
bump
