Grounding Wire
0 Members and 1 Guest are viewing this topic. Read 2369 times.
JoshK
Grounding Wire
« on: 25 Sep 2003, 09:31 pm »
Ok, this might seem like a dumb question but I read the manual for the bearing setup and it discusses attached the bearing grounding wire to the bottom of the bearing using the supplied 6-23 bolt. However, the obvious admission is where do you connect the other side of the wire to?  I am assuming it is meant to be 'grounded', but what would suffice as a good ground?
What have others done is this regard?
Marbles
Grounding Wire
« Reply #1 on: 25 Sep 2003, 11:17 pm »
Mine is grounded to my Phono pre
JoshK
Grounding Wire
« Reply #2 on: 26 Sep 2003, 03:39 pm »
Thanx!  Yeah I ended up finding that in another manual, just not the one I had.
