0 Members and 1 Guest are viewing this topic. Read 30909 times.
Care to share the schematic, BOM, and TX specs? I like the EF86. Wonder if the new production one is any good
Last time I used the series resistor for the screen as per the schematic but remembered having to up the value as it was too low. I always wondered if it would sound better with the regulated screen and hopefully will know in a couple months. I certainly sounded VERY good as per the schematic.
IIRC, he warned against regulating screen grids without regulating B+
For simplicity you may want to consider some of the older gas regulator tubes as they have sufficient current range for use as a shunt regulator for screens.
We also have a 6V6 version on the bench (not parafeed, but much bigger East German output iron. And i should have enuff coke bottle 6V6s to match the big 5U4 coke bottle rectifier.
but I also used the smaller 9-pin 0A2 (150v) and 0B2 (105v) tubes for ~250 volts
