0 Members and 1 Guest are viewing this topic. Read 11559 times.
Of course the difference between binding posts is not audible.
I would prefer the copper substrate rather than the brass substrate personally and it wouldn't effect the cost much...
QuoteOf course the difference between binding posts is not audible.Well if that's the case why don't you just go on down to Home Depot and buy four galvanized 3/8" bolt's and nuts then? Much cheaper than those P.E. binding posts you like, besides it wouldn't be audible right? John
Beryllium Copper Alloys can have less than 22% the conductivity of pure copper whereas Tellurium Copper Alloys will have greater than 85% the conductivity of pure copper. See link:http://www.premieringots.in/chromium-copper-alloys.html#tellurium Scotty
A brass appears to have a conductivity of 28% compared to 101% of ETP copper which commonly used in household wiring.http://www.kp44.org/ftp/ElectricalConductivityOfMaterials.phpScotty
