Ok Gentlemen, (& any ladies possibly present as well). This has been a weekend largely committed to football, thus causing a delay in my response to some of the recent and wonderful posts. Most notable were the mention of both the Orions and the Nomads. When I first read about the Orions I thought, “This is it; this is The Solution.” Then, after reading a bit more, I realized that to use these would require an external active XO / equalizer. I thought that was quite acceptable, I just would have to find room for another box. Then I realized that tri-amplification was mandatory, most likely with the MC amp recommended by the designer, or I would have to consider the purchase of 4 more Channel Islands D100s. This seems like a hoop through which I am reluctant to jump. For one thing, the more complex the network, the more opportunity there is for me to mess it up. And regarding amps, I don’t want to spend the money for 4 more CIA mono blocs, and I am very resistant to going with some MC box with which I am unfamiliar. For that matter, in the back of my head I always like having the “parachute” of returning to tubes. Still, the pedigree of the Orions design is impeccable. It could be that I am just lazy and cheap and trying to find a way to justify why I should not invest in these.
Here is a quote I have to share. “…audiophiles stubbornly resist the inherently superior powered-speaker approach, although in this case the power amplifier is not built in and thus a number of alternative amp choices are possible. In any case, other things being equal, an electronic crossover is preferable to a passive crossover, and direct coupling of the drivers to the amplifier is preferable to coupling through a network. The active (powered) format is simply better, in every way—but who will believe me? Only those who already know.” All righty then, regarding the design of the Orions, I have just quoted Peter Aczel. I never saw this day coming. I just looked out the window to make sure there were no winged hogs fluttering about!
Both the Nomad Ronins and the Orions satisfy my dipole appetite ala Dahlquist, Acarian Systems and Alon. In other words, the designs of Carl Marchisotto seem to have greatly influenced my audio sensibilities. Dipoles just make sense to me. If I talk myself out of the Orions, then I believe the Ronins would be the way for me to go. I will have to check with Paul Hilgeman to see if I would be better served by the powered model with the plate amp, and also whether my tastes would be better served by the model with the metal cones or the paper cones. If I get a Ronin with a plate amp, well I am at $5500 rather than $4500 and there goes the budget. Of course, if I stick with the Orions, my budget is shot no matter what. With the Orions I would go the DIY route and build them incrementally.
This still leaves the offerings from Salk Audio, specifically the Veracity HT3. In addition to this there is the TL configured QWs that were mentioned in an earlier post, and the Salk site is now promoting a V3 model, which possibly could be thought of as a budget HT3. I am sure I could be happy with the HT3s, even though they are not an open baffle (dipole) design.
That leaves us with SP Tech. The old roadie in me really salivates at the thought of these monitors. It’s just that I want the $5500 Timepiece 3.0s rather than the $3K Timepiece Minis. But what the hey, everything that looks “right” for me seems to be a bit above $5K – though the Orions could be quite a bit above that if I don’t go DIY. Now, the only thing left for me to ask about is the EMERAL PHYSICS CS2s. What are these?? They obviously are an open Baffle design. Zybar *George,* could you / would you comment on these? Hmmmm???
BTW, PSP, I want to thank you for bringing the “Orion system” to my attention in the first place. I have the Bis SACD releases of the Beethoven 4 & 5, plus the 9th with the Minnesota Orchestra. I confess, I have trouble calling this organization the Minnesota Orchestra. The first orchestral piece I ever heard was Prokofiev’s “Peter and the Wolf.” This was in 1958 at Northrop Auditorium with the Minneapolis Symphony Orchestra under the direction of Stanislaw Skrowaczewski (if I remember correctly.) I was on a fourth-grade field trip provided me by the Wayzata Public School District. This is one of the few things I remember from grade school.
Just to summarize then:
1. Orions
2. Nomads
3. Salk Veracity HT3s / V3s
4. Salk QWs
5. SP Tech Timepiece Minis
6. Emerald Physics??
And once more, and additional comments are welcome and invited.
