0 Members and 1 Guest are viewing this topic. Read 17512 times.
I'm trying to think what I personally would do if such were my list of choices (and assuming my listening room would accommodate any one of them). I'm a "keep it simple stupid" kind of guy so I'd probably gravitate toward speakers that didn't require multiple amps. But sound-wise, I think this is a near-impossible call unless you could audition each one carefully in your room. Plus the realization that you'd almost certainly be happy enough with any of them (unless you're the obsessive-compulsive type).Your open-mindedness, including the willingness to DIY or consider using four amplifiers & external XO, and your apparently flexible budget, make this a pretty tough choice. Maybe first, decide how much you're an open-baffle guy. Then decide how many amps you want to deal with.The Emerald Physics sound like a steal ($3000) until you consider their amping requirements, but a lot of this probably comes out in the wash. All that being said, if it were me, and I'd said my budget really was $4000 or under, I'd almost certainly get either the QWs or the Timepiece Minis. Knowing what I know about a good 2-way design with good bass reach (and with the memory of being electrified and pinned to my chair last night by a superbly recorded Beethoven overture) I'd happily save the extra $thousands for more music. Good luck...
...Now, the only thing left for me to ask about is the EMERAL PHYSICS CS2s. What are these?? They obviously are an open Baffle design. Zybar *George,* could you / would you comment on these? Hmmmm???
I will concede two points: I want not only to hear a detailed rendering of the orchestra, but I also want a aural impression of the hall in which they are playing. (Fussy, ain't I?)
No system come close to reproduce that live music effect. When you hear people talk about "live sounding" speakers, you have to question whether the "live sound" comes from room reverberation or it's part of the recording. If it's part of the recording, then any properly designed speakers (as many have suggested on this thread) would reproduce the sound beautifully. If it's not part of the recording, then it's either the room or it's the speakers "adding things that should not be there to begin with". So when it comes to live orchestra performance in a huge acoustic-friendly hall, nothing come close.However, when it come to amplified live Jazz performance in a bar, pub, a small hall, or any places which is not acoustic-friendly, then a properly setup two channel system can actually sound better than live.
140 dB??22.5K euro???I know it isn't April 1 yet!
IMHO, if you want good orchestral sound reproduction you have only 2 options. You either build a huge room with similar acoustics to a concert hall or you use a small and dead room with multichannel (not 5.1) reproduction.
Sadly, most orchestra recordings were simply not capable of giving you that "aural impression of the hall" that you want to hear. It's not the fault of the speakers, most of the time it's simply because what you want to hear is not in the recording itself. So when it comes to live orchestra performance in a huge acoustic-friendly hall, nothing come close.
This kind of thinking is just plain wrong and very narrow minded to boot. You can get the impression of a hall if you know what you're doing.
Yeah right.. keep dreaming...but I'm a realist...you can certainly create "an impression"..but how close can you get to the "REAL THING"?? 60%, 70%?? That's not close enough to me Quote from: sunshinedawg on 10 Jan 2008, 01:03 amThis kind of thinking is just plain wrong and very narrow minded to boot. You can get the impression of a hall if you know what you're doing.
Quote from: AliG on 10 Jan 2008, 01:59 amYeah right.. keep dreaming...but I'm a realist...you can certainly create "an impression"..but how close can you get to the "REAL THING"?? 60%, 70%?? That's not close enough to me Quote from: sunshinedawg on 10 Jan 2008, 01:03 amThis kind of thinking is just plain wrong and very narrow minded to boot. You can get the impression of a hall if you know what you're doing.Might be time to listen to some vinyl Bro.
