0 Members and 1 Guest are viewing this topic. Read 5390 times.
Isolation without room in a room:If you have the height, use Dri-Cor on the floor. This gives good feel, provides additional isolation, and helps with temperature. Build the walls on top of this floor. Use Sill plate gasket under the walls and caulk the wall to the floor.Dri-cor is too expensive. I used 7/16 OSB over 1/4" OC Fanfold and roofing clips to hold the plywood sheets together. Power nail where needed. You can borrow my gun. Then, as Bryan said, you can build walls right on top and use 3" drywall screws to fasten toe plate down. You get a cushioin and some insulating value.Frame all walls 1/2" short of joists above. Use PAC International DC-04 clips to decouple the wall/joists. RSIC-1 clips and hat channel on the ceiling. Double drywall and Green Glue between layers.I used these at about $5 a pop, there is a local dealer: http://www.kineticsnoise.com/arch/isomax/index.aspx The hat channel can be bought locally. HD no longer sells it.All openings in the room (switches, lights, outlets, etc.) should be housed inside 3/4" MDF boxes attached to the structure (walls) or decoupled (joists) and caulked to the drywall. The only penetration then is the hole for the romex which you use caulk at putty on to seal it.I did this in my ceiling, but feel it is overkill in the walls if using green glue and double dw. Make sure to use a solid core wood door - not a typical insulated metal exterior door (exterior is fine with the seals but the metal/foam won't block anything). why not Bry? Work pretty darn well I think.Plan ahead for as few penetrations into the room as possible. Building soffits AFTER the room is drywalled and bringing in HVAC and electrical inside those will minimize the intrusions and help with isolation both ways. This is probably the most difficult thing to get right - that is proper circulation of air and low noise at the same time.That's probably enough to get you started for now. I have all of the materials you need available except the Dri Core and hat channel. I'd be happy to put together a materials list of exactly what's needed and the costs involved if you want to go this way.Inside acoustics:The room is large enough that we can potentialy build some of the treatments into the room to minimize the visual impact. It will cost a bit of length but you have plenty of volume to play with. What specifically is needed will be determined by how much of the above you implement and a few other factors that impact the inside aspects of the bare room's acoustics.Bryan
Boxing the penetrations is absolutely critical - sorry. You can use 8 layers of drywall, clips, and all the green glue you want but if you cut 12 6" diameter holes in the ceiling for can lights, it's all wasted money as the sound will go right through a thin tin can light fixture. In the walls, it's the same. You're going to have most likely at least 10 outlets in a room that size plus a switchbox with at least 3 switches. Add up all the area of those openings and ask yourself if you'd leave a hole that big in your wall and expect the sound to stay inside.
Six GIK 244 panels at front/side wall first reflection points and front corners made maybe a 2% improvement in my properly proportioned room.
If you can't do battery power or you don't have power abberation issues, run separate 20 amp circuits with 12 gauge wiring to each A/V receptacle. Wire all grounds together and separate from the rest of the house. Use receptacles of choice, but any hospital grade (red are the tightest) will do.
Dayglow, my walls are concrete block with no living rooms on the other side. I don't see the benefit of using "double walls." I do wonder about using 2x6's vs. 2x4's??? But then again, why stager the studs if the wall behind it is nothing? Why wouldn't I just stand off the wall a couple inches from the block?
WHen you use hat channel the wall becomes "thicker" and you will have more space to work with so 2x4 up against the cement would be my choice.
