Musical Fidelity X-CANS Upgrade Kit?
0 Members and 1 Guest are viewing this topic. Read 2285 times.
cporada
« on: 30 Dec 2007, 07:17 pm »
Has anyone out there tried the Rock Grotto Musical Fidelity X-CANS Capacitor Upgrade Kit for the version 1 X-CANS?  If so, what differences did it make to the sound of the unit and how difficult was it to do the mod's?  Was it worth the cost?  I'm using my X-CANS with a pair of AKG 701's, if that helps at all.
Thanks in advance for any input
Chris
Turnandcough
Re: Musical Fidelity X-CANS Upgrade Kit?
« Reply #1 on: 31 Dec 2007, 02:06 am »
I brought my X-Can V3 and showed the RG upgrade package to the owner of Solen Canada. He found some of the mods to be a bit unnecessary. He replaced the output caps with a couple of Black Gates, a couple of Solen caps somewhere else in the path and removed a resistor. I'm happy with the result. He wanted to use Solens in the output stage except for that value they're the size of beer cans.
