Need your help experts
0 Members and 1 Guest are viewing this topic. Read 767 times.
chgolatin2
« on: 29 Dec 2007, 04:14 pm »
Is modding worth paying the extra high price, does it really improve sound quality or is it only a marginal notice?  Also, this is a silly question but, their is a site where audiophile cables are sold but they are used.  Can someone direct to that site PLEASE!  and Lastly, any opinion on a good Tube Phono stage?  So far I looked into the Pro-ject II and Jolida product since they are modestly priced.
I have a Jolida JD100 with a level 2 mod, however, I never heard the unit without the mods so I cant tell the difference.  Wondering if I should upgrade/mod my current  Jolida RC 1000.
Thanks in advance!
bpape
    • Sensible Sound Solutions
Re: Need your help experts
« Reply #1 on: 29 Dec 2007, 04:18 pm »
http://www.usedcable.com/
As for modding, it really depends on what it is, what you're looking for, who's doing the modding, etc.  Some mods can be as simple as swapping a couple of caps/resistors, changing a volume control, installing bypass caps, etc.  Others can be quite involved.
Bryan
chgolatin2
« Reply #2 on: 31 Dec 2007, 12:39 am »
Thanks for the link!  Got it!  Any other suggestions or advise?
« Reply #3 on: 31 Dec 2007, 01:33 am »
Tubed phono pre-amps:
http://www.hagtech.com
http://hollowstate.netfirms.com/  (Mapletree)
http://www.ramlabs-musicreference.com/  (Space Tech)
6moons.com and TNT have done a number of reviews of modded pieces.
In general I'd start with a well built piece that needs only limited additional investment (why invest 3 or 4 times the price of the original component in mods versus just buying a better component to start with?).  I'd also look for modders that have a good warrantee or that the original manufacturer honors their work.  I'd avoid modders that apply the same mod to every piece.
