0 Members and 1 Guest are viewing this topic. Read 6314 times.
I guess I just don't understand this low pass crossover thing. I set my pre- x-over to 45 and my mains to small, which means everything from 45hz and below should go to the sub correct? How come when you turn the sub x-over up higher it gets considerably louder. I didn't think it could play anything up higher than what I had it set for. Shouldn't I just set it for where my mains end? Man am I confused. BTW this sub is just mainly for music. I just wanted a little deeper bass and I swear I can hear where it's coming from. Thanks for all your help.
Thanks for the replies and being patient with me everybody and I think I have it sounding pretty good. If I could bother you with one more question please. There are 2 settings in the pre-amp for high pass and low pass, either 6db or 12 db. Which would be better? I can't tell a difference when I change between the 2. Thanks!
Dynaudio contours 5.4. Thanks
