How to print Castanet front and back panel drill guide?
0 Members and 1 Guest are viewing this topic. Read 1346 times.
Theo
I'm using the stock 1402KV chassis but not ordering panels from FPE.  There is no drill guide that came in my Castanet kit.  There is a drill guide in the PDF manual for the panels.   I tried to print the it using "Page Scaling: None" from Adobe Reader 8, but still not able to print to size that matches the panels that came with the stock 1402KV chassis.  I don't have software that opens the FPD files posted on the Castanet webpage.  Please help!      :scratch:
dnewman
Re: How to print Castanet front and back panel drill guide?
« Reply #1 on: 28 Dec 2007, 12:21 am »
The Front Panel Designer software is available free from Front Panel Express
(http://www.frontpanelexpress.com).  If you run Windows (or
a Windows VM under Mac OS like I do), you can
1. Download it from Front Panel Express,
2. Install it,
3. Run it and open the panel designs,
4. Print them.
I don't have Front Panel Designer running right now, but I recall there
being an option to print to scale (1:1) and with centers marked.  So,
as long as your printer prints  1 inch approximately = 1 inch (1 cm ~= 1 cm),
then you're in business.  It's how I ensure the accuracy of my panel
designs before paying $$ to have them manufactured.
Dan
Theo
« Reply #2 on: 28 Dec 2007, 12:24 am »
That's exactly what I need.  Thanks.
2. Install it,
4. Print them.
Dan
